DK40 Box Blade size? 72"? 78"? 84"?
/ DK40 Box Blade size? 72"? 78"? 84"? #21
It's strange how different it is from area to area. I've seen several medium duty ones (including a couple of Bush Hog brand 6 footers) in pretty good shape that could be bought for $350 - $450. But I knew that, ultimately, I wouldn't be happy with anything but a really heavy one since my soil is so hard when it's dry.
I measured our road, the traveled/maintained section is 10' wide, there is about another 2' on each side that is grassy. I need to be able to cut this grassy section down. I walked the road and checked the sides carefully, some area's I could drive the tractor over them with no issues. Other area's have a 1'-2' drop off, the area where the culverts are have a 4'-5' drop off. I am not getting close to that edge and I need to be able to grade to the edge of the drop off to give the water a place to go, so a 72" BB or LP is out. I haven't found a 78" LP, the 84" LP's are out of my budget. Present plan is to get either the 78" or 84" BB to grade the edges of the road and get the road close to where it needs to be. Then rent a 72" LP, $70/day, to do the final road clean up. I am leaning towards the 84" BB as it is only $50 dollars more than the 78" and gets me that much further from the edge. I just need to check that the 84" BB will fit my trailer.
/ DK40 Box Blade size? 72"? 78"? 84"? #23
The 84" should put the edge of the BB approx 12" past the outside edge of your rear tire. That's probably as close as you want to get to that dropoff. I think your plan to go with the 84" one is a good plan, especially for a measley $50 more.
The 84" should put the edge of the BB approx 12" past the outside edge of your rear tire. That's probably as close as you want to get to that dropoff. I think your plan to go with the 84" one is a good plan, especially for a measly $50 more.
If my tires are 71" outside to outside, then I figure the BB will extend just over 6" outside the wheels. I figure/hope I can adjust the 3pt stabilizers and move the BB off to the side by another 3" or so, then I will have 9" between tires and edge... hopefully that will be enough. ROPS will be up with seat belt on when I do this. Now to wait for delivery, scheduled to be in 2 weeks, I am hoping the ground won't be frozen by the time it gets here.
/ DK40 Box Blade size? 72"? 78"? 84"? #25
I have straight blades (bush hog 50-07, land pride 35-84, and a woods HBL96) that will offset to the right or left of the tractor, plus the blades will angle and pivot. You might want to consider something like these for working the edges of the road. They can be found inexpensively, I just picked up the land pride last weekend for $300 off CL in good condition.
I have a straight blade that angles, pivots and can be adjusted offset, it doesn't cut thru the grassy edges very well at all. It is not very heavy which might be part of the problem. This is why I was going with the heavier BB w/ scarifiers to break the grass up so it can be worked. I also have some leveling in the yard to do and the straight blade just floats over the grass, I can't get it to dig in until I break up the grass.
/ DK40 Box Blade size? 72"? 78"? 84"? #27
The more pounds per foot the blade has the better it is going to do.
/ DK40 Box Blade size? 72"? 78"? 84"? #28
An 8-foot BB should extend 12" past each side. 6' tractor tire width, plus 1' on the left, plus 1' on the right = 8'.
Am I missing something?
/ DK40 Box Blade size? 72"? 78"? 84"? #29
:duh: Doh!! As Jim just pointed out to me in a PM, he's looking at an 84" (i.e., 7'), not an 8' BB. Cranial flatulence on my part.
/ DK40 Box Blade size? 72"? 78"? 84"? #30
/ DK40 Box Blade size? 72"? 78"? 84"? #33
that's the same one Roger. You saying, I should buy it?
You edited you post, before it was just a search for box blades.
You should buy it if you don't have one.
Sent from my GT-P3113 using TractorByNet
/ DK40 Box Blade size? 72"? 78"? 84"? #34
Its missing some rippers. What should I offer?
/ DK40 Box Blade size? 72"? 78"? 84"? #35
I think it is a 78". I see it says 3578 so IDK if it is a HRL3578.
Here is what they are new. http://www.tractorhouse.com/list/list.aspx?ETID=1&Manu=LAND+PRIDE&Mdltxt=HRL3578&mdlx=exact
I don't know what rippers would cost for it but $700 is probably fair. Check the cutting edges for wear, they are probably reverseable.
Don't make a offer, find out what their best price is then shoot them with a lower price. Also explain to them it needs 4 rippers and they are going to be X amount of dollars.
/ DK40 Box Blade size? 72"? 78"? 84"? #36
The ad say's 7ft land pride box scraper w/ ripper teeth $700 obo. It looks like a roll-over blade not hydraulic.
/ DK40 Box Blade size? 72"? 78"? 84"? #37
I am pretty sure it is a 78". The guy I bought my scraper blade from kept calling it a 6' even after I told him it was a 7'. That box blade has a hinged back. I think they believe it is a 7' and are pricing it a $100 a foot, like my scraper blade was :D. You may get it for $500 or $600.
/ DK40 Box Blade size? 72"? 78"? 84"? #38
That's a 6'6" blade with manually retracting scarifiers and a floating tailgate. The lever sticking up is how you would pivot the scarifier bar up. It is a good one to look at if you're in the market.
/ DK40 Box Blade size? 72"? 78"? 84"? #39
I see it now the numbers, DOH on my part. good eye on yours.
/ DK40 Box Blade size? 72"? 78"? 84"? #40
case 370 glass door never installed (A61306)
case 370 glass...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2022 CATERPILLAR 330 EXCAVATOR (A60429)
2022 CATERPILLAR...
57" HYD LOG LOADER GRAPPLE (A60429)
57" HYD LOG LOADER...
BUYERS PREMIUM & PAYMENT TERMS (A59904)
BUYERS PREMIUM &...
78in Bucket Skid Steer Attachment (A59228)
78in Bucket Skid...
