Starter problems for a Kubota
   / Starter problems for a Kubota
Is there a relay that the key switch energizes that switches power to the starter solenoid? There usually is. Do you have a circuit diagram? What about fuses in the starter solenoid circuit? Without a diagram or understanding of how the circuit works, it is pretty hard to diagnose. On the key switch when you turn it to the start position, what color of wire is energized? where does it go from there? just keep on chasing it..We know that the starter solenoid is not energized to pull up, so why not? you have to figure out what is in the middle.
James K0UA
I do not know if there is a relay for switch. I will try to get a wiring diagram.
I don't know if there is a starter relay. Do you know where they would put it?
I will check that PTO switch.
   / Starter problems for a Kubota #16
You have seat switch, pto, clutch, hst peddle, fuse box, and a main fuse. Also check for good connections of the bat. leads, on the - check at frame and the + at the starter. If you want to turn it over just take a small jumper wire, hook one end to battery and the other end to the solenoid after you unhook the wire coming from the dash.
   / Starter problems for a Kubota #17
Please dont stand between the tires when shorting across the starter.
My dad was starting a car in a parking lot by jumping across the solenoid and when it started it was in gear, luckily it was in reverse altho it wasn't lucky for the car parked across the road. The gearshift was in park but the shift cable broke in "r" thats why it didnt start.
   / Starter problems for a Kubota #19
My 2630 had a total of 5 "neutral" and seat switches. Anyone of which, if not engaged prevented starting. That's the first place I'd look.
f.
Thank you.
It was the PTO safety switch.
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2002 Sterling Bucket Truck (A50323)
2002 Sterling...
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
