Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #391
I wont buy! no Cummings just a over sea diesel and I hear they had problems before
   / Ram1500 EcoDiesel V6 revealed! #392
Cummins is built here in Indiana. Not over seas, like that's a bad thing. My tractor and two of the three vehicles I own are imports.
Chris
   / Ram1500 EcoDiesel V6 revealed! #394
A HD F150 may have much more payload, but the added weight will make ride and mileage sacrifices. You can have the best or everything. Not both.
RideRite kits !! RideRite kits !! ;)
   / Ram1500 EcoDiesel V6 revealed! #395
Do they allow Plant tours?
Not sure. I have 2 friends that work there. On manages the cafeteria and the other is the #2 man there. I have never been offered.
Chris
   / Ram1500 EcoDiesel V6 revealed! #396
Chris
I think he meant that he the engine in this Ram is not a Cummins but a Fiat import, so he won't buy one.
   / Ram1500 EcoDiesel V6 revealed! #397
God, I hope they don't put the Cummings in them, those are worse than the Duramacks.
   / Ram1500 EcoDiesel V6 revealed! #399
The point being that their payload is lower than typical. Every truck has a weak point and payload is it for the Ram. Ram excels and leads the class in many other things though as you mentioned. No truck is perfect. If it only had better payload to match such strong powertains.....one would be in my garage.
While I understand your point, I don't really expect Chrysler to cannibalize their 3/4ton+ sales by doing what you (and I) would like to see here. Just another case of gear-head wishes being trumped by business reality.
Rgds, D.
   / Ram1500 EcoDiesel V6 revealed! #400
I like the Firestone products I've seen. For my personal recreational use, I'd probably look at using these, on this 1500.
For commercial use on this 1500, in a truck fleet - No. Just buy a 3/4ton or larger.
Rgds, D
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2020 DRAGON ESP...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
