Metal Cutting Saw
   / Metal Cutting Saw #11
Unless that metal cutting blade has a significant negative hook I sure wouldn't pull it into the stock. By pushing it you would have the same condition as using the blade in a Skill Saw.
As has been stated, it's possible for the teeth to break 'even with wood cutting' so I hope the lack of guard was just for photographic clarity.
   / Metal Cutting Saw
All useful important points.
On the guard, yes I use it. I have been using wood saws of every description much of my working life and still have all original parts in decent condition. Saw safety for me is Rule 1, 2 and 3. For this application, now that I now it works, I will make a full shroud to contain chips and possible loose teeth.
On the blade, the Makita has significant negative hook and also a controlled feed design. So it is relatively easy and safe to use. Probably all metal cutting blades are similar.
On push or pull. I push the blade. Until now, I haven't used a radial arm saw in probably 20 years. But in the old days on wood, I pushed it through the work rather than pull. I don't know why the manufacturers instructions were to pull the blade. It is much easier and safer to push in the usual way. That is true even if using a proper radial arm saw blade for wood, which should have zero or negative hook.
Another point on saw setup. Radial arm saws were always a bit finicky. All adjustments need to be well snugged up to avoid jumping, chattering, wandering. That goes double for metal cutting. I set it up a bit tighter than I would have for wood. For anyone considering this application I would recommend Jon Eakes book. He provides detailed setup instructions and photographs for DeWalt, Rockwell, and Craftsman radial arm saws. It costs about $15 on his website and is worth every penny. Radial Arm Saws
Again, thx for feedback.
   / Metal Cutting Saw #13
Another concern I have is heat build up when cutting metal. Never having used a metal cutting circular saw, I am totally ignorant in this reguard. I know even when cutting wood that blades can heat up. I am also interested in how well the radial saw works cutting compound angles in bar or tube stock. I think my craftsman will cut lumber upto about 16-18 inches wide and is capable of cutting long angles and bevels at the same time. Is this capability retained when cutting metals? I realize I will lose some thickness cutting because of the smaller dia blade, and I think I read that the Makita blade was rated for a thickness cut of 2 1/2 in ferrous metals, way thicker than I would ever cut in bar stock, but with working with rd or sq tube????
   / Metal Cutting Saw
I've used the Makita cordless on various shapes and thicknesses, never noticed heat buildup. For intermittent use I wouldn't anticipate an issue. On compound cuts -- I don't intend to use the radial arm saw for anything other than simple flat cuts in metal. It should be OK for simple miter cuts too, although I have never needed to cut a miter in metal. I wouldn't attempt compound cuts in metal. For wood, my 15 year old Bosch sliding bevel miter saw does perfect compound cuts, and never needs any setup, so I wouldn't use the radial arm saw for that either.
   / Metal Cutting Saw #15
I sure thought whether you pushed or pulled a radial arm saw is whether the blade rotation is rotating toward you for normal radial saw. The saw should bite into the material as you pull..
If you push a radial arm saw, you have to reverse the blade.
Either way, I would lock the material down and pull or push real slow.
My 14 in Dewalt metal cutting saw drops down into the metal and slings the pieces to the back, which means the blade is cutting from top down.
   / Metal Cutting Saw #16
With a Radial arm saw, I think if the blade took a bite as it is pulled into the material, you would face a real danger of the blade getting a bite and launching violently toward the operator. I have seen it happen with wood, pretty sure it could be worse if cutting metal. Pushing the blade thru the material would have a lifting effect on the piece being cut, which I assume the reason the OP added extra heavy clamping to his radial saw. I think the lifting effect can be minimized with proper cutting depth setting of the saw, just like adjusting cutting depth with a circular saw. I dont think you would have to reverse the blade but I'll wait on the OP to verify how he mounted his blade. With a chop saw like your 14in dewalt, or my Makita for that matter, the material is securely clamped to the saw table and the blade is fixed so that it can only go up and down. On a Radial, the saw is fixed for depth of cut, ( it is adjustable up and down), but the saw travels on a rail to transverse across the piece being cut. With 18inches of travel, thats a lot of room for the blade to jump if it was to get in a bind. I havent tried cutting metal with a radial saw, but I am pretty certain if I do, I will be pushing the blade thru the material and not pulling.
There is another thread on here somewhere where they where using a radial saw to mount a plasma cutter in place of the saw. I am going to look for that thread. I think the plasma cutter ideal might be a safer way to make the cuts than a saw blade.
   / Metal Cutting Saw
Very true. Keeping the material locked down tight is important. One of the pictures shows the milling machine clamp I use. Tightening up all the adjustments of the saw also important. No movement in the material, no movement in the saw. Then a slow steady cut into the material.
If you start a radial arm cut with the motor head out at the end of the arm, close to you, and push away from you toward the column, the blade rotation and cutting action in relation to the material is the same as a sliding miter saw or skilsaw.
   / Metal Cutting Saw #18
Mudd, I've not built one yet - so far, it's just a brain fart and a sketch, although I've made some build notes in a separate file.
Right now, it's on Jim Gherkin's compressor thread starting here
http://www.tractorbynet.com/forums/welding/294946-i-am-looking-air-compressor-11.html
at post #105 -
but I'll start a separate, appropriately titled thread in Welding forum sometime soon (not sure when I'll get started on the actual build, there will likely be others ahead of me til I get a couple other projects out of my face but I'll start the thread so it's easier to find... Steve
Oh, I'm also considering a higher speed rated metal blade for the same saw, if it doesn't hold up I'll only be out the price of the smaller blade, instead of several hundred for a saw and $100-150 for 14" blades.
One plus if the saw blade holds up - it's nearly impossible to cut a 45/45 notch out of square tube on a CHOP saw without cutting too deep or not deep enough - with a radial, you could set a 45 deg. bevel and then reverse the piece - then when you bend the piece, you'd have a smooth outer corner with only 3 sides welded - This would have the added benefit of leaving you a "pre-made gusset" from the piece that's removed...
   / Metal Cutting Saw #19
See what you get for hijacking a thread on air compressors. And all this time I thought you had already got your radial plasma cutter built. LOL
Anyways, I did find this vid on Utube, re-purposed radial arm saw - YouTube of a radial saw cutting metal. They used an abrasive blade instead of a metal blade. Also found a radial converted to a cnc router, but didnt save the link.
   / Metal Cutting Saw
Here is an update showing the blade shroud I put together this morning. An aluminum plate covers the open operator side of the guard. It is carried on studs attached to the original guard. The studs make use of existing 10-32 threaded holes probably intended for a lower guard of some kind. The shroud can be adjusted up and down and rotated to suit the work. The side plate carries two guard extensions front and rear, made from aluminum channel. They can also be adjusted to suit the work. With the shroud in place, chips stay under the shroud or go out the front. A few drop out the back at low speed. Now that this essential safety element is in place, I can start to use the saw as planned, for flat wide steel and aluminum. Thanks for various comments focused on safety, I appreciate that.
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
Stainless Steel 1" Spool (A49461)
Stainless Steel 1"...
