Wiley's jeep tractor
   / Wiley's jeep tractor #21
I have a Topeka jeep bought off the county- which used a side mounted mower for mowing ditches. the lift for the mower and the mower head all operated off the front of a continetal red seal 4cyl. motor. It has dual 15 inch tires on the back and 4 wheel drive on the front. Large hyd. tank on back end and some serious counter weight hung under the left side of the frame to counter balance the mower. Way under powered for most tasks.
We definitely need pictures of that!
   / Wiley's jeep tractor #22
I would think a old two wheel drive truck with a second transmission in it and either change the tires or chain them and weight the rear, would be a better choice, if you can fine one with two speed low range. you may not need a second transmission, many of the ones made during the 30's and 40's the trucks were shortened up as well,
The Epitome of American Ingenuity - Doodlebugs, Scrambolas, Jitterbugs, Field Crawlers and Other Farm Rigs
https://www.google.com/search?q=Doo...ZFoHlyAGbt4DgCw&ved=0CCsQsAQ&biw=1280&bih=800
   / Wiley's jeep tractor #24
Hello everyone. I'm new to this forum and just wanted a bit of insight from all those that are experienced. I own a 2002 Wiley's jeep and was wondering if I could modify it and run it as a tractor. I saw a couple of videos of people in the US doing it and also found out that Wiley's themselves made a tractor jeep long ago. According to some basic calculations I did, if I add a secondary reduction after the gearbox the jeep should be able to produce enough traction. So is this possible ? Or am I missing something here a. And any idea why something like this doesn't already exist ? A car or jeep that can be used to plough and till.
Thanks in advance for your response.
We get this questions now and then at our Web site. I start by saying that it certainly possible to use a modern Jeep to pull a two bottom steel wheel plow and a pull type disc. In fact, the original Farm Jeeps were designed to use drawbar implements. The 3 point hitch was an add-on not made by Willys. Right after WWII the Farm Jeep was marketed to the small farmer who was still using horses or mules and he needed to be able to use the implements he had. So if you can find some antique farm implements you can use your jeep (or most 4WD pickups) as a tractor. How well they work is another matter.
From years of talking to farmers who owned used Farm Jeeps I think there were several factors that caused Jeep to not continue the farm jeep options. The biggest change was that farming in the USA really changed in the 1950s and 60s. Farms got larger and the days of 40 acres and a mule were long gone. More powerful powerful tractors were needed to work large fields. Jeeps farm market had disappeared.
Here is a great video that shows what I'm talking about - https://www.youtube.com/watch?v=MaVkRZL5G_c
   / Wiley's jeep tractor #26
I have a 2001 Jeep TJ that I use to plow/disk and cultivate a clay field with. Just make sure the clay is fairly dry. The plow is an old IH 2 bottom trip plow. The disks are a tandem set of drag disks and the cultivators were at the time of manufacture horse drawn. This Jeep is also my 'daily driver'.
Another point: Weight. A lot of traction, also known as tractive effort, is a function of weight.
You can have all the torque and horsepower you need, but if you can't hook it to the ground with a combination of wheel size, tread pattern and weight, all you'll get is wheel spin.
You also need to consider the effect of the rear suspension. Tractors have no suspension other than the cushioning effect of pneumatic tires. If you have leaf springs, some of the torque that you're trying to put on the ground to do work will result in twisting the rear end in the spring mounts and "winding up" the springs.
At the least, you'll have wheel hop. At the worst, you break the springs, universal joints or driveshaft.
None of the above is a "deal killer" you just need to think about matching your load to the amount of usable tractive effort you can generate without breaking things.
Hey thanks for replying
I realize that traction really has the biggest role to play here. And I'm honestly quite worried about my jeep rear crumbling down. And that's why i thought I'd confirm. What I probably will end up doing is just get a couple of ol and small tractor tires and modify my keep's rear end up a bit. Then try a 3 row plough with a normal draw bar hitch. Let's see how that works out.
Just curious...where did you find a "2002" Willys anything?
Hey. I'm from India. Mahindra markets the jeep here under a different name like some one else mentioned. And they obviously use a different name. But I thought id just mention that to avoid too much confusion here.
   / Wiley's jeep tractor #29
There's an old trick used in the desert with 2wd cars in the 1920's and 30's to prevent wheel hop and loss of traction.
Jack up the rear of the vehicle so the axle is hanging. Cut some wood blocks so they fit tightly between the frame and axle, and wire them in place using holes and screws. Now you have a solid rear suspension that won't bounce.
It might help in your situation.
Bruce
A neighbor has one as /pine pictured. 3pt hitch & pto & 4WD. Very cool. I don't think you'll do much plowing with a 2WD. I remember years ago as a kid seeing jeeps used on the highways mowing. Seen them set up as ditch diggers with a rear "ditch witch" style chain, and a few other "arrangements" that were odd. I think that someone posted one here that had a loader/backhoe set up a year or so ago.
Yeah jeeps have been used with all sorts of front and rear implements. Seen a bunch of pictures of those. Goes to show how absolutely marvelous that tiny thing really is.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Year: 2006 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 57,884 Plate: Body Type: 2 (A55788)
Year: 2006 Make...
2014 International ProStar Truck, VIN # 3HSDHSJR1EN768255 (A54865)
2014 International...
2019 INTERNATIONAL RH613 SINGLE AXLE DAY CAB (A54607)
2019 INTERNATIONAL...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
