Wiley's jeep tractor
   / Wiley's jeep tractor
I would think a old two wheel drive truck with a second transmission in it and either change the tires or chain them and weight the rear, would be a better choice, if you can fine one with two speed low range. you may not need a second transmission, many of the ones made during the 30's and 40's the trucks were shortened up as well,
The Epitome of American Ingenuity - Doodlebugs, Scrambolas, Jitterbugs, Field Crawlers and Other Farm Rigs
https://www.google.com/search?q=Doo...ZFoHlyAGbt4DgCw&ved=0CCsQsAQ&biw=1280&bih=800
Okay that was good advice. I'll probably wanna try that to see how that works out. Coz India still is in the small farm age. If foresee a small jeep with farming capabilities (although limited) working out really well for a farmer who had let's say, less than 10 acres. For an affordable cost, you get a jeep/ pick up truck and a tractor. I will look into this combination though. Thanks for that.
We get this questions now and then at our Web site. I start by saying that it certainly possible to use a modern Jeep to pull a two bottom steel wheel plow and a pull type disc. In fact, the original Farm Jeeps were designed to use drawbar implements. The 3 point hitch was an add-on not made by Willys. Right after WWII the Farm Jeep was marketed to the small farmer who was still using horses or mules and he needed to be able to use the implements he had. So if you can find some antique farm implements you can use your jeep (or most 4WD pickups) as a tractor. How well they work is another matter.
From years of talking to farmers who owned used Farm Jeeps I think there were several factors that caused Jeep to not continue the farm jeep options. The biggest change was that farming in the USA really changed in the 1950s and 60s. Farms got larger and the days of 40 acres and a mule were long gone. More powerful powerful tractors were needed to work large fields. Jeeps farm market had disappeared.
Here is a great video that shows what I'm talking about - https://www.youtube.com/watch?v=MaVkRZL5G_c
Exactly what I had in mind. The US is at the point that the farm jeep just doesn't make sense. You canny operate that big a farm with something like the jeep. But India on the other hand, average size of a farm is around 5 acres. And The drudgery of the farmers in India is horrible to see. Oxen and hand held tractors are a pain to operate. The farm jeep would be a good solution. Which is exactly why I wanted to know about the tech. So if I enlarged the wheels, tinkered with the gearbox and maybe a put a lowers reduction and added let's say a ballast of around 200 kgs In the back .. It'd work ?
I have a 2001 Jeep TJ that I use to plow/disk and cultivate a clay field with. Just make sure the clay is fairly dry. The plow is an old IH 2 bottom trip plow. The disks are a tandem set of drag disks and the cultivators were at the time of manufacture horse drawn. This Jeep is also my 'daily driver'.
Hey thanks for the info. The clay you're operating on, is it more to the soft side or hard ? I'd be interested in knowing if there's any specific kinda soils the jeep would not be able to handle Hard soils can be difficult to plow in
   / Wiley's jeep tractor #37
   / Wiley's jeep tractor #38
If you want a versatile road and field unit take a look at the Mercedes Benz MB Trac tractors discontinued in the 1990's and the still produced range of Mercedes Benz Unimog.
Germany following World War 2 was forbidden from making military transport vehicles, the response was the Unimog, first designed in 1945 as an agricultural tractor. But it had the capability of a tractor, 4 equal sized 4 wheel drive with a tray, a sort of truck as well as a tractor with all terrain capacity. A short history of Unimog is at: Unimog - History of an All-Rounder - YouTube
When you watch the video note the high clearance under the differentials, which are mounted up to the chassis and drive transmitted down via transfer cases on each wheel ie independent suspension
Try this as a challenge for entry and departure angles as wel as clearance between wheels: Unimog Offroading - YouTube
I could watch these unimog videos for hours and would love to have one myself, take a look at its suspension travel and extreme angles: 4Xformance9 by DF -Unimog extreme 4x4- - YouTube
The unimog morphed into the MB TRAC which could carry 2 ton behind the driver, had 3 point hitch front and back and pto front and back, full air brakes and inn Europe I believe rated to a combination of 32 tons, plus a road speed of 80 kmph (50 mph), see : MB-Trac in Sweden - YouTube
Note the tyres reversed to reduce the wear experienced on sealed roads with R1 tread agricultural tyres.
Or another sort of conversion to 4 tracks: www.lr-mad.co.uk/en/cuthbertson_tracked
Okay that's ecavtly what I've been searching for. Thank you for that. That's perfect !!! Never knew that existed. And I'm guessing the later farms and bigger requirements in the US caused it to be discontinued ?
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2023 Chevrolet Tahoe (A55853)
2023 Chevrolet...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
2020 KUBOTA RTV...
2018 Kenworth T680 Tri- Axle Dump Truck (A55788)
2018 Kenworth T680...
