Home Depot Bulldog 700 4x4 UTV?
   / Home Depot Bulldog 700 4x4 UTV? #41
I never messed with the governor, if I remember correctly, it is a spring type. I think you would need to change the spring to get higher RPM (I am sure it is set conservative by the factory and could be upped a bit). I never hit the governer until I moved the foot lever stop bolt to give a little more throttle, yours may already be set at that point.
Hmmm...foot stop lever bolt.....hmmm. But I would NEVER mess with that because it would void the warranty....."I know that, don't you think I know that?" ...Attorney Nathan Thurm, Saturday Night Live:laughing:
   / Home Depot Bulldog 700 4x4 UTV? #43
The side view picture with the guy waving, it looks to me that the front tires are bigger than the rear????? Just wondering...
Yeah they really do look a lot bigger. Don't suppose someone put them on bass ackwards do you?
It is an illusion, but the rear wheel was down in pressure so I topped them all off today and checked the lug tightness.
I really like to see this on the back, even though many foreign parts are used, they are assembled in my home state:
And what the heck are these two side by side sprockets with chain on them? All they do is wrap around the drive shaft coming from the front Dif:
   / Home Depot Bulldog 700 4x4 UTV? #46
That looks like the rear diff in the picture, if so, the double sprocket chain drives your front wheels in 4 wheel drive. The cable with the lever locks your rear diff so both rear wheels pull.
   / Home Depot Bulldog 700 4x4 UTV? #47
That's a "Double Chain Coupler" it allows for a little bit of difference in angle between two parts and is an easy way to mate different shaft types together.
Aaron Z
   / Home Depot Bulldog 700 4x4 UTV? #49
Aaron Z
It basically is two chains put together with extra long roller pins. As a Sportworks service center I have had them apart for repairs on other models of Sportworks units.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
Electric Concrete Mixer (A51573)
Electric Concrete...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A51247)
2016 WITZCO RG-35...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
1275 (A50490)
1275 (A50490)
