Home Depot Bulldog 700 4x4 UTV?
   / Home Depot Bulldog 700 4x4 UTV? #41
I never messed with the governor, if I remember correctly, it is a spring type. I think you would need to change the spring to get higher RPM (I am sure it is set conservative by the factory and could be upped a bit). I never hit the governer until I moved the foot lever stop bolt to give a little more throttle, yours may already be set at that point.
Hmmm...foot stop lever bolt.....hmmm. But I would NEVER mess with that because it would void the warranty....."I know that, don't you think I know that?" ...Attorney Nathan Thurm, Saturday Night Live:laughing:
   / Home Depot Bulldog 700 4x4 UTV? #43
The side view picture with the guy waving, it looks to me that the front tires are bigger than the rear????? Just wondering...
Yeah they really do look a lot bigger. Don't suppose someone put them on bass ackwards do you?
It is an illusion, but the rear wheel was down in pressure so I topped them all off today and checked the lug tightness.
I really like to see this on the back, even though many foreign parts are used, they are assembled in my home state:
And what the heck are these two side by side sprockets with chain on them? All they do is wrap around the drive shaft coming from the front Dif:
   / Home Depot Bulldog 700 4x4 UTV? #46
That looks like the rear diff in the picture, if so, the double sprocket chain drives your front wheels in 4 wheel drive. The cable with the lever locks your rear diff so both rear wheels pull.
   / Home Depot Bulldog 700 4x4 UTV? #47
That's a "Double Chain Coupler" it allows for a little bit of difference in angle between two parts and is an easy way to mate different shaft types together.
Aaron Z
   / Home Depot Bulldog 700 4x4 UTV? #49
Aaron Z
It basically is two chains put together with extra long roller pins. As a Sportworks service center I have had them apart for repairs on other models of Sportworks units.
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
New/Unused 10ft Workbench with 30 Drawers (A51573)
New/Unused 10ft...
