Loader for John Deere 5303
/ Loader for John Deere 5303 #1
Dan Dargeloh
Member
Milford, Nebraska
John Deere 5303
Hi, my name is Dan and I'm new here. I have a John Deere 5303 that I am considering putting a front end loader on. That tractor is so easy to get on and off of compared to my two other tractors with loaders, that it would be worth the expense. I am starting to get older now, so that little John Deere is looking better and better all the time to this IH fan! A loader would make an already handy tractor even better. Any recommendations from others, who own one of these tractors, as to what make & model loader to buy would be greatly appreciated. Thank you.
/ Loader for John Deere 5303 #2
You might consider looking at tractorhouse.com, fastline.com and machinefiner.com and look up your tractor and see what loaders are them.
You might also look at 5x20 tractors and then look up the loader manuals from the following URL and see if they work for your tractor and maybe look at the e tractors.
Sorry, but this is the best I can do to help you.
John Deere Ag - New Equipment: Technical Publications - Equipment Search
/ Loader for John Deere 5303 #3
Several manufacturers make loaders which fit the 5303. The ones I found:
John Deere 512 and 553
Koyker 185
Quicke 200 (available through Rhino and Bush Hog) Q21 and Q28
Westendorf - many different models, they recommend the CC-300 and MAX428
Woods LU126
HTH.
GreenWannabe and JD5210, thank you for the info. I have called a few dealers around here and got some pricing on Allied, Koyker, Deere, and Westendorf. I have tentatively narrowed my choices to the Deere 553 and the Westendorf TA 180. Both are rated for 80-90 horsepower. Koyker only produces the 185 for this application and it is rated to 60, which makes it on the light end for the application. The quote on the Allied wasn't even in the ball park. I like the Deere 553 due to the fact that it would allow me to leave my weight bracket on the front of the tractor to use when the loader was off. BUT, that means that the only mounting point for the loader is in the middle of the tractor, instead of the front and middle on the other style which hooks to the front of the tractor also. Any thoughts on this from you or anyone else out there. A tractor broken in half would be a revolting development!
/ Loader for John Deere 5303 #5
We have a westendorf on a Kubota L4310 at work... bought new. Been on tractor about 4 years. Stout loader...
/ Loader for John Deere 5303 #6
I would look at a loader mounted on a tractor at your JD dealer. They've used a center mount design for a number of years now, and I haven't read any problems with it breaking the tractor. I think their mounts distribute the force pretty well, but you can tell more about it by getting underneath and looking at one.
/ Loader for John Deere 5303 #7
I have a 553 Loader on my 5075E. It was $6K from the dealer installed.
It's one of the sturdiest looking mounts / loaders I have seen on a utility tractor that size. Lots of iron! :thumbsup:
I looked at one on a later model and slightly bigger tractor yesterday. The only thing between the loader mount and the front end is the engine. I think I would feel alot more more comfortable with a loader that mounted there and the front of the tractor, thereby distributing the load. Unseen badger holes can cause some severe shock loading on equipment and I'd sure hate to find out at what point the engine block would break.
econometrics, my bad. The tractor I looked at was a 5025 series with a 553 loader on it. The loader brackets mounted in the middle of the tractor. I found a 5300 with a 520 loader on it. The 520 is a mid mount loader also. The 5300 is an earlier version of my 5303. The mounting brackets on it mount on the bell housing and reach forward to the front end, tying the tractor together. I'm sure the brackets to mount a 553 to my 5303 would be the same, eliminating my fear of "splitting" the tractor. Now it comes down to the price differential between the JD 553 and a Westendorf TA-180. Does anyone know if it is true that you can't get the heavy duty bucket on the John Deere with the skid steer mounting? My Deere dealer told me the HD bucket is available only with the global mounting and not the skid steer.
/ Loader for John Deere 5303 #10
I do think that is the case, and your dealer telling you that is probably right.
I have the global carrier on my 553. I actually like it a lot. It's the beefiest carrier I've seen on a tractor. And the bucket you reference really is a a beast too.
/ Loader for John Deere 5303 #11
I have a 553 loader on a 5045E. It is plenty strong and the mounting hardware plate extends forward to just behind the front axle so when you raise a load it makes tractor and loader act like a scissor without sending the load stress through the engine block. They have been building these tractors with these loaders for a long time and have it figured out. There are ballast requirements for when you are doing heavy loader work that should be followed if you want to save front axle wear. My 5045E should have 2000lbs. on the 3PH when loading manure or other heavy material. The owners manual for the 553 loader does say that for 5x03 series tractors (section 50-6) that you might have to adjust the muffle toward the turbo charger to clear one of the hoses. I love mine.
/ Loader for John Deere 5303 #12
I have a JD 522 FEL on my 5303 4WD tractor. I would suggest if looking new go with the JD 553 and if looking for used either a JD 522 or 553 if you want the ability to remove the loader. If removal not a concern you could look for a JD 512 non-removable loader. I had one of these put on a 2WD JD 5105 and had no issues. I have removed the current JD 522 loader once mainly just to see how easy it was. I typically find I use the FEL for something most every time I operate my tractor.
vtsnowedin, the first tractor (can't remember model, old age I guess) I looked at with a 553 loader on it was a larger model with a 4 cylinder engine and front wheel assist. The mounting brackets were connected to the center of the tractor with nothing I observed going forward. This tractor had a very substantial engine block and the connection between the block and front end was very substantial. I then found a 5300 with loader, and saw that the mounting bracket for that one tied into the front end. That's the way it would mount on mine also. Now it all makes sense. As for ballast, did John Deere plan these tractors this way in order to sell lots of cast iron weights? Great little tractor with no traction. I've add beet juice to my rear tires. It cost way more than the calcium, but no way was I putting calcium in my almost new tractor. If I need more weight, I will build something to hang on the 3pt for times I need it. This will be a great tractor for putting the chain saw and stuff in the bucket to go cut and trim trees out of fence lines and other places. Far better than trying to carry the stuff on a 4 wheeler or in a cart behind a 4 wheeler where stuff bounces out. This tractor is so easy to get on and off of compared to my old farm tractor with a loader, it will all be worth the effort.
/ Loader for John Deere 5303 #14
Each model has it's own mounting bracket and the 5M's as well as 5225. 5325, and 5325N s don't have the front arm and one the 5500 narrow has a cross brace underneath. I have beet juice in my rears 1400lbs. of it and 300 lbs of chains on in the winter. I have plenty of traction. A ton ballast block is still recommended on the 3PH if your gonna load all day. I don't put the saw in the bucket. I forget it's there and start to move or dig something and almost run it over.( old age for sure) I bungee cord it to the ROPS behind the seat but I'm thinking of building a mounted scabbard outside the soft cab perhaps on the fender for easier access.
deere5105, thank you for the response. I have decided to go with either with the 553 or the Westendorf TA 180. The advantage of the 553 would be the ability to leave my front end weight bracket on the tractor, for use if I do remove the loader. I would like to have the heavy duty bucket along with the skid steer mount, but John Deere doesn't offer that. It's one or the other. Then again my Westendorf catalog only lists one grade of bucket. Decisions-decisions! Either way, I'm going to "pull the trigger" shortly.
vtsnowedin, I about died laughing about forgetting about the chain saw and almost running over it. We all have our moments! ;-)
Because the Deere loader was made in Mexico, I decided to go with one that is made in Iowa. Why spend your money for something that is foreign made, when you can keep your money in this country, right? Well take it from me, buy the factory made, dedicated model, no matter where it is made, not some "fits all" model. This has turned into a nightmare, I am about ready to pull my hair out. I think money spent on quality control, along with common sense designing, would be money better spent, than for slick advertising. :-(
/ Loader for John Deere 5303 #18
Ugh, sorry to hear that. Frustrating!
/ Loader for John Deere 5303 #19
This is what I was going to tell you, but it seemed you had your mind made up already. I'm sorry you are having the trouble though. There's no better loader for your tractor than the one the the factory designed the tractor around in the first place, but that's the proverbial water under the bridge now I guess.
This loader would be fine, if the quality control was better. BUT, inadequate, poorly written, and hard to follow installation instructions, pieces that don't fit together properly, way too many totally unnecessary fittings on the hydraulic lines, and just plain poor workmanship on other than the actual loader assembly itself, makes for a disappointing unit. The main structure of the unit is built like a battleship, too bad they couldn't of finished the total package off as good.
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2018 VOLVO L180H WHEEL LOADER (A60429)
2018 VOLVO L180H...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
