Looking at old grain trucks... Need help.
   / Looking at old grain trucks... Need help. #41
You'll hear it in that ole truck. No insulation in the cab, motor right in front of you, you'll learn the sound of when to shift quickly. Still say buy both. When will you ever have this opportunity again?
   / Looking at old grain trucks... Need help. #42
I agree as about buying both. You said 800-1000ea. He'd probably be happy to see them both go to you for 1600. Think of it as a parts truck or a savings account. The two together will be worth two grand or more pretty much no matter what.
   / Looking at old grain trucks... Need help. #43
Yes, if you can afford and especially have a place to keep under cover I would buy both.
About the 2-speed rear, if it works it can be handy but you don't absolutely need it the way you will be using; and when it malfunctions on an old truck like that it's a problem. Anything vacuum operated on old stuff is potential problems, whether it be wipers, axles or brakes. That's why the comments about brakes; are the trucks vacuum hydraulic or air? Most likely hydraulic and the cylinders and booster can give problems if truck has been parked, so check them out.
It's not true that gearing and top speed has to be the same on both trucks. With a 2-speed rear they could be speced where low range was lower than a single speed straight axle and high range could be higher/faster road gear.
What are the trannies in these trucks, 4-speed or 5-speed? Most likely 4 speed but maybe the 1950 has a 5-speed which could compensate for the single speed axle getting off the line.
Assuming they're both 4-speeds, if the axle is working you can start that one off in 2nd on the road as long as the axle is in low. If the axle's not working or you don't want to take a chance with it you can probably always start out in 1st gear and be OK. If it were me I wouldn't get into split-shifting old stuff like that, why take a chance on busting something or getting hung up between gears like others have mentioned. If the 2-speed works OK, just start off in low range, run thru the tranny gears, and once in top gear on the highway shift the axle into high using the clutch, like using an overdrive; why look for trouble on a nice old truck. If you want to practice downshifting the axle, first try going from high to low without shifting the tranny at the same time; downshifting the axle takes more skill than upshifting and can be harder on the axle if done wrong or something is not working right.
I wonder why the old truck was being used more in recent years than the newer one, I guess you'll find out when you look them over. Maybe more miles on one or it needed something fixed. Check both trucks for rust on the frames, especially where the spring shackles mount to the frame in the back (front too). Look for rusty hydraulic brakes lines which might need replaced.
Good luck and I hope you get both trucks, a lot of parts might be interchangeable. Your old friend seems like a a very nice guy.
   / Looking at old grain trucks... Need help. #44
My '56 White WC22 has an Eaton electric shift two speed rear axle. I've never driven it under load but driving it empty takes some getting used to because the Clark 5 speed OD trans is not synchronized. The two speed axle works great. This truck has a flathead 6 cylinder 145 hp White Mustang engine. My '59 White 4400TD originally had a ten speed Fuller Road Ranger trans but I changed it out for an Eaton 13 speed trans. The '59 has a 220 Cummins in it.
You have to remember these veteran trucks were built when the truck speed limit usually was 45-50 mph. They are geared for slower speeds and don't have the power for high speed rear ends unless you're running empty.
   / Looking at old grain trucks... Need help. #45
My neighbor had a White that looked like your '56, may have been a '55. It had 10.00-20 rubber, flathead engine, 5 speed x 2-speed electric axle and he would load 10 ton on an 18 foot body. Is your WC22 a little heavier than that? I had a '56 GMC 18K GVW at the same time, 270 OHV, 4-speed/2 speed electric Eaton. It would run 55+ mph with no problem on the flat highway. The Eaton worked good but 2 times it got water in the motor unit and had to be repaired/replaced. I know it took a toll on the clutch when we were waiting for parts and had to leave the axle in high for a while. You'd be slipping the clutch when backing up with a load or the driver would try to start out in 2nd instead of 1st. These trucks were probably around $4K or less bought new, more for the White of course.
   / Looking at old grain trucks... Need help. #46
Both great looking trucks! I like the 59 more though. Awesome set!
I've been doing some more research and found an online owner's manual that showed that they are basically the same. The split just gives lower gearing. The recommended pattern was 1L, 1H, 2L, 2H, 3L, 3H, 4L, 4H.
They're both 4 speed.
The manual says the axle is a vacuum shift, so no clutching is needed. According to GM, just flip the switch, let up on the gas, wait a couple seconds and ease the gas back on.
I think part of the reason the '50 was licensed later was because it had a hitch on it and it was needed to tow stuff. The shorter box makes hitching up a little less awkward. The '52 was still used, but just hauling grain from the fields to the bins, so it wasn't being licensed anymore, as it never left the farm.
I don't think getting both would fly with the wife. ...And yes, my friend is one of the nicest guys I've ever met. Our families have shared many memorable experiences together for close to 30 years, and we will miss them dearly. I'll be very satisfied to have just one.
   / Looking at old grain trucks... Need help. #48
When shifting a 5 & 2 the pattern changed when you got to 4th. You went from 4 low to 5 low then back to 4 high to 5 high.
Not sure how many were like that but I'm sure it confused a lot of drivers, me included until I looked at a shift chart on a sun visor.
You could tell the Wife what a rare opportunity this is to get both. ???
   / Looking at old grain trucks... Need help. #49
IIRC, the maximum GVW on the old 6400's was around 19,500 to 20,000 lbs, although that might be later 50s models to get that high. Chevy had two models of two ton trucks back then, the 6100 and the 6400, the difference was that the 6400 had a longer wheelbase. The 6100 was designed for a 9' body, the 6400 for a 12' body.
There were three different types of 5 speed transmissions available back then, a gathered ratio with a gear ratio around 1.45:1 in 4th gear, a short fourth version with a 1.20:1 or 1.18:1 ratio in 4th (that one had the odd shift pattern), and an overdrive version with a 1:1 ratio in 4th, with an overdrive between 0.85:1 to 0.75:1. The overdrive might be a regular "H" pattern or the odd pattern, depending on manufacturer.
But on the Chevys, a 4 speed was much more common, even with a 2 speed axle. I don't think Chevy offered an electric shift for the axle until later on.
The tag on the pillar says GVW is 16,000 lbs. No published weight on a complete grain truck that I can find, but there have been numbers between 6500 and 8000 lbs floating around, depending on equipment and accessories. I'll have to use a truck scale so I can find my true load capacity once I make my decision and purchase.
I've been finding more data on these two models and I'm pretty sure both of these trucks have the 4 speed. As it turns out, the gear ratios between the single speed rear and two speed are close, but not identical.
Single speed axle: 6.17 to 1
Two speed axle H: 6.13 to 1
Two speed axle L: 8.10 to 1
Joe
2015 Ford Focus (A51694)
2015 Ford Focus...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
KSI Conveyor (A55301)
40' CONTAINER (A51244)
