Gas in a Diesel engine
   / Gas in a Diesel engine #41
the problem I am having is the engine will start and run for about 10 mins then it will slowly die. if you try to start it again right after it will not run, but if you wait awhile it will start again and do the same thing. when it does run it revs up and idles fine and blows no smoke. This problem seemed to start when the weather got cold but I don't think its gelled fuel. the fuel filters have been replaced recently. I am thinking fuel pump but I haven't seen one fail like this before.
It sounds like water in the fuel system. More than likely in the tank. Are there any fuel scenes at banjo fitings, ect. Is it a gravity system to the Injection Pump? Make sure you have good fuel flow.
Chris
I did completely drain the tank and refill with fresh diesel with additive and no change. there is no injection pump on this engine just one mechanical fuel pump that feeds the injectors.
   / Gas in a Diesel engine #43
Make sure the fuel tank vent is not plugged.
I replaced the filters and filled them before installing and now the engine won't start at all. anyone know how to bleed the fuel line from the tank to the primary filter? Is the best way to pressurize the tank and crank the engine?
   / Gas in a Diesel engine #45
It sounds like either you are not getting fuel or possibly air. If the engine has an emergency shut down lever make sure it is in the open position. There are two fuel lines, one from the tank and a return line. If you pressurize the tank you will have to disconnect the return line and block the fitting from the tank. Wait for a good flow from the return line before trying to start the engine.
   / Gas in a Diesel engine #46
This is your injector pump.
Chris
   / Gas in a Diesel engine #47
It's been my experience that a diesel engine fueled with gasoline will run, but the injection pump will get ruined.
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2003 CATERPILLAR D6R XW HI-TRACK CRAWLER DOZER (A51406)
2003 CATERPILLAR...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A55218)
2019 Energreen EVO...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
