Implements narrower than tractor
   / Implements narrower than tractor
So your tractor tire track is 10.5 ft wide measured to the outside of the rears and your chisel is 9 ft wide. So assuming the chisel is centered on the 3pt hitch, your concern seems to be the 9 inches on each side that's not covered by the chisel. I suppose there's a small compaction problem that results from this situation, but it doesn't appear to me to be a show stopper.
If you're concerned about leaving tire tracks in your newly chisled field, maybe you could rig up a simple drag to rub out the tracks and hitch it to your chisel.
Good luck
Yes you are correct in the situation. And yes I agree it is not the end of the world but a 9" strip every pass is nearly 10% of what I cover. If it was 9" on a 40' plow it might not be as significant but it kinda seemed like a lot percentage wise.
My tractor got here yesterday and the duals had to be removed for transport. I have been working on sliding the inner tires all the way in so that I can put the duals on in the narrowest configuration. Spent 6 hours yesterday moving one tire. It is a royal pain when they have not been moved in 30 years and are full of fluid and loaded up with cast weights.
I think my easiest solution is to weld a 12" stub on the outside of the chisel plow and add a shank on each side. Might cost me a couple hundred in parts and take a couple hours. Certainly will be easier then wrestling tires back and forth.
   / Implements narrower than tractor #22
Now you're talking:thumbsup:
Good luck.
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
