New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS?
   / New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS?
OK, I think I have it serviced for the most part, radiator flush- front dif- engine oil, I used DELO 15-40. And new hydraulic fluid. I see there is a small black hose coming out of the back, maybe an over-flo for the crank case?
Now I have assembled by AUGER for the back. I have one question. It says to slip the spring loaded drive shaft onto the PTO shaft and it will click when secure. I cant get it to click or secure and if and when I do, how do I remove it, if it clicks or locks somehow? I have never used a PTO or implements.
Just need to get the shaft on and I think I am ready to go.
RUMBLON
   / New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS? #32
Rumblon, that's a lovely 'Cuda. I'd love to see more photos of the restoration process.
To expand on what California said: If the 1401 has everything in good shape that's a good enough price to be able to resell it and not lose anything. However, I would treat the tractor as a powered wheelbarrow with the ability to lift a load to 6' high. It will scoop loose material, but I wouldn't expect to be able to do any digging.
The 1401 has its front axle set rather far back, and is VERY nose-heavy with a loader. With a scoop load of dirt, mine sometimes needs to be in 4 wheel drive just to move itself through loose dirt, and that is with a box blade on the back with about 250 lbs of extra weight added. Without anything on the rear, I imagine attempting to lift a loaded bucket would instead just hoist the back tires off the ground. I would strongly recommend budgeting for something to counterbalance the loader if it doesn't already have something.
OK, so everything seemed to go ok but now I cant get the auger to attach to the PTO shaft? Here are some pics of the end of the auger shaft and the PTO shaft. I have checked online but cant find a video or anything for fieldmaster to show how to attach it. I did find other companies and one one of them there is an extended shaft with a pin you pull out. This does not have it. Does it look like Im missing parts? I cant push this auger shaft onto the PTO shaft any further than it is and it wont lock into place and if it did, I cant see how you would remove it?
Any advise as I have never installed any implement ever. I was hoping to start digging fence post holes today.
YEP, THAT WAS IT, my wife actually looked at it and said the same thing before I got this reply. I had to pull that colar out and slide it on and it clicked. simple. Thanks for the reply.
Dave
   / New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS? #35
Pretty sure just a play on words but just wanting to make sure you used combination transmission/hydraulic fluid and not just hydraulic as stated in post 31.
Winston I hope I used the correct stuff-- I used this
   / New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS? #37
If that bucket says it can be used where Deere 303 is specified - its fine.
   / New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS? #38
I do not pretend to be a lube expert. I looked at numerous sights about the Super S and conclude I don't know.
   / New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS? #39
Greetings Winston1:
I joined tractorbynet to learn more about maintaining a 1948 International C tractor my Dad left me when he passed away. But he also left me a Yanmar 2210D 4x4 tractor that I have struggled to maintain as well. I am a computer guy not a back yard mechanic by any stretch. Can you tell me where you (I) could obtain (download from a web site) a pdf copy of the 2210D manual you are all referring to in this thread? Thank you. Ronald
   / New 2 me YANMAR 2210 BD 4X4- NOW-SERVICE QUESTIONS? #40
A retailer and the distributor recommend it as a suitable replacement for the John Deere 303 fluid that Yanmar specified.
The distributor notes it is for moderate temperatures (like single-grade motor oil); outside that range they recommend their premium fluid. That sounds like 303 to me. Remember Yanmar specifies 5 minute warmup before moving the tractor, probably to get the hydraulic fluid warmed up. But nobody warms up that long!
Rural King
Atlantis-usa
Applications
Super S SuperTrac 303 Tractor Hydraulic Fluid is designed for use as a replacement fluid for the hydraulic, wet brake, and transmission requirements of equipment manufacturers where a product of this quality is recommended, including:
... John Deere 303, J20A ...
SuperTrac 303 Tractor Hydraulic Fluid is recommended for ambient temperatures between +32F and 104F (0C to 40C). For ambient temperatures outside this range or where a premium tractor hydraulic/transmission oil is required, please use Super S Premium Universal Tractor Hydraulic Fluid.
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
2019 F150 (A56438)
2019 F150 (A56438)
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
Drago Olimac 6R Corn Head (A59814)
Drago Olimac 6R...
