Carts or Wagons to Pull Behind Tractor
   / Carts or Wagons to Pull Behind Tractor #41
All of KK's implements are yellow but the XB-Dump Trailer is orange. KK rates XB @ 1.5 tons.
Lightest two-axle Pronovost, model Puma 347AGT is 3,000 pounds. Heaviest two-axle Pronovost, model Puma 10610, is 10,000 pounds.
How is the build on the XB? Does it dump 100% of dirt loads?
It does look very similar to Pronovost, although in looking at the Pronovost web site briefly I didn't see one exactly the same as the XB.
The build seems decently robust, certainly enough for my use. The cylinder is long enough that it will tilt the bed pretty steep, for good dumping/emptying. You can open the tail gate like a pickup, or trip the lever in front to open the bottom of the tail gate like a dump truck.
Of course, the heavier the load, the more work it takes to pump the lever of the hydraulic pump to raise the bed. It pumps in both direction, so the bed raises as you lift and push down the lever. It can take some pretty good effort to pump with a real heavy load.
As ishiboo mentions, the XB implements are pretty much an exact match in color to Kubota, and in my opinion are a pretty good match in general for the BX line. (I also have the box blade and tiller.) For the OP, the color might clash a bit with his JD... :)
   / Carts or Wagons to Pull Behind Tractor #42
This one looks nice... Not sure on the price.
   / Carts or Wagons to Pull Behind Tractor #43
The problem with trailers having the bed OVER the wheels is that they are unstable, loaded, on uneven ground.
If you want a trailer to follow everywhere your tractor will go with 4-WD the load should be carried low, between the wheels.
LINK:
www.muts.ca
   / Carts or Wagons to Pull Behind Tractor #44
This one looks nice... Not sure on the price. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=367570"/>
Atv wagon is the same designed to tow behind an atv. They make them for ABI. Around $2100 delivered with 1500 lb capacity.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
198367 (A51243)
198367 (A51243)
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2004 Ford F350 Harley Davidson Pick Up (A47477)
2004 Ford F350...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
