Box Blade Width?
   / Box Blade Width?
Most of the planes I see have angled blades, how well does that work on a lawn, I would think that would tend to pull the material to one side and create a crown which would be ok for a road or driveway but wouldn't straight blades be best for leveling a lawn? I suppose the angle may help the blades cut into hard soil as well.
   / Box Blade Width? #12
If you notice my land planes are straight blade not angled. My main use is for lawn and pasture smoothing, using a land plane reduces the time spent to get a field with bumps and dips straightened out.
There have been many discussions on threads about the straight vs. angled blades, I don't think it is a big deal. For my use the straight blade works well for both gravel roads as well as pastures and lawns. If you need to crown a road or ditch the sides get a rear blade. Land planes with angled blades don't move the gravel enough to build a crown properly.
All these implements have their place, the basic ones I use are the box blade, land plane, rear blade and landscape rake. I have small ones for the little x749 and larger ones for the 4520 and they all play a part in fixing up lawns and pastures. Just understand while there is some overlap in what these implements will do it is better to have the correct tool for the job if you have a frequent need for it.
   / Box Blade Width? #13
I would like to add that as far as LPGS not moving much dirt, if the ground is damp, not wet, but damp, like perfect working moisture, my LPGS will move roughly 3-3.5 cubic yards of material at a time. I would say that that is about 3 times what I can move with my box blade. If a person was to put a tail gate on their LPGS, then a large amount of material would be able to be moved no mater what the conditions.
Now that amount may only be for my scraper, since it has 22" tall sides, is 7' wide and 8' long and that is not very common, but for people to think that you can't be moving very much material with them is incorrect. As far as material moving sideways because of the angled blades, yes, about 1/2"- 1" of sideways movement per pass, and that is only with smaller amount of material. If that amount of side movement is a problem,:rolleyes: then you would need to have straight blades. ;)
I would think that anyone that does a lot of dirt work would have those 4 implements. Each has it's purpose and makes life so much easier when used for their intended purpose.
   / Box Blade Width? #14
Jenkins is correct. The angled blades don't move a whole lot of material to one side, certainly not enough to establish a crown. I use mine to shape my wife's arena and it's pretty dang flat. It's a dirt arena, not sand.
   / Box Blade Width? #15
I see that Brian was typing while I was. Yep, a land plane will move a lot of material, especially if you travel slow enough for it to collect. The only thing that keeps me from using a land plane for all of the gravel driveways I do is the length of the land plane tends to ruin my quest for perfect edges when swinging a curve. I'd also like to have a heavier land plane with hydraulic or handle actuated scarifiers.
   / Box Blade Width? #16
Jenkins I have an M6800 so have 60+ HP. I want a landscape rake to collect tree branch parts. Was thinking the 1 1/4" x 3/8" tines wold be better suited and was considering making mine, 96" wide. Your opinion please?
   / Box Blade Width? #17
John, isn't that what a landscape rake is for?? :rolleyes: I know I know, time is money. :sigh:
   / Box Blade Width? #18
Aren't those things for gathering sticks? I guess I could use one to make pretty lines like a Japanese zen garden... :D
   / Box Blade Width? #19
I just did a 150 drive way with a six ft. box blade.Had to remove about 6 in.of sod/top soil.In four wheel drive with the scarifiers down and a full box I had to put the L4240 in low range.I can pull my two bottom plow with ease in medium range.Even with my 8ft.snow plow medium is used.Bottom line a box blade can have a lot of drag.
   / Box Blade Width? #20
JRP,
I worked over an old property that was an apple orchard with sizes from twigs to limbs. Had to get it clean enough to laser level so can't have much debris. I used my landscape rake with every other tine removed, it worked okay but not excellent. Lots of small pieces slip through the 3" spacing. What I did to solve this problem was to make a second pass with a pine needle rake to get the little stuff. The combination of the two worked pretty good.
I mention the above because one of the things I want to build this winter is a rake similar to the pine straw type with round tines about 1/2" diameter on 2" spacing. The problem I have is that the wide tines will hold too much dirt if you make a pass over 50 to 75 ft. If your travel distances while raking are kept short enough then you could use the heavier 1 1/4" tines. Your tractor should not have a problem with an 8' rake at any rate. I would be careful using heavy tines on good grass areas as it can tear it up.
Everything Attachments makes a nice pine straw rake and has pictures and pricing on their site.
2019 GALYEAN...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
John Deere 204L ABSOLUTE SALE (A56436)
John Deere 204L...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
