I'm admitting defeat---- Last time on this...........
   / I'm admitting defeat---- Last time on this........... #31
Maybe a dumb question, but could it be running too lean?
   / I'm admitting defeat---- Last time on this........... #32
I really appreciate all the replies, guys ! Keep 'em coming if you have any ideas. Looks like I'll have to take the engine apart, but I'll have to do it soon since I have to work outside and I'm really going to need this thing for winter. I really intended to put a drive-in shop out here, but then this thing with Jo (wife -43 years). I sure hope I get an update today. SORRY, I don't mean to whine. Anyway if you guys think of anything else, please let me know. in the meantime, I'm going to look for a gasket kit. Please let me know if you think of anything else. I feel like a real stooge on this one.
You are right to address this as a cooling system problem. No other cause could present so acutely. Assuming you 1st verify that coolant flows well, then a head gasket or some other breach that communicates with combustion in some way is the only thing that fits. ... The upside down headgasket, if its possible to assemble that way, could surely block critical flow paths. ... When did the problem start??
larry
   / I'm admitting defeat---- Last time on this........... #33
As previously stated I don't think the cooling system is the issue. Looks like the symptoms rather than the causes have been addresses.
The possibility of late timing and lean mixture is very likely. In particular if somebody leaned the mixture for economy or there is a gasket leak. Then somebody retarded to the timing to prevent reduce knocking .
The centrifugal weights could be stuck and not advancing timing.
The accuracy of the temp gauge is suspect. Sounds like it's something aftermarket that have been Jerry rigged . Check the accuracy.
Of course she is gonna boil over if you run a machine hard and hot then shut it off. There is still heat soaking into the coolant from the engine and no fan or water pump to dissipate the heat. She's gonna geyser . Run the engine at 1200-1500rpm for 5 minutes to cool down if she is that hot.
How hot is hot? Some people panic when the gauge moves from the lower side of green to the higher side of green.
Are you lugging the guts out of the engine using the rotary cutter? Most people do.
Why tie up the pro with a pto pump on the loader? Deere is noted for having a high flow, high pressure hydraulic system.
Is the pto hydraulic pump loading the engine? Where is the loader oil tank and cooler?
The loader should be supplied from a T in at the high pressure line after the priority valve. Use a closed Center valves on the loader. Return the oil via a ported filter cover.
Is the fan pulley, alternator pulley and fan belt new. Not looking ok but actually new?
Don't super tighten the belt either to prevent slippage.the extra tension will ruin the water pump bearings and alternator bearing?
Are you running the tractor at rated pto rpms or just putting around?
Are you running the tractor nude or with all the sheet metal bolted back on?
   / I'm admitting defeat---- Last time on this........... #34
Glen you must be kidding WHERE"s the ""oil cooler"" for a simple loader operation?? I doubt anyone can heat the oil much operating a farm loader.
larry
It's been this way since I bought it Larry. That's why I've replaced all the cooling parts . I'm going to try some more stuff before I start taking the engine apart.
   / I'm admitting defeat---- Last time on this........... #36
I guess I'm not understanding this. It dumps coolant AFTER shutdown not while running. Once it cools, how low is the coolant? Could you be overfilling? Have you put a IR thermometer on it? What's the engine actually running? What about the Radiator? Top and bottom hoses?
   / I'm admitting defeat---- Last time on this........... #37
OK. Now were getting somewhere. ... Unfortunately theres no development history we can access. I have a 2010 Gas so maybe it models yours closely. Why dont we experiment? :
,,,,Drain your coolant and save it.
,,,,Fill with water, but a little low. Cover the core about 1/2"
,,,,Cap it and start it up. Squeeze the top radiator hose and blip the throttle a few times from lo idle using the carb linkage. Does the coolant pressurize immediately and increase as you blip repeatedly?
,,,,Before it heats, remove the cap and look in while you play with rpm. Is the fluid flowing noticeably? Is it bubbling?
,,,,Continue as it warms toward midrange. Does it exhibit flow now? Does any bubbling stop or get worse?
,,,,Stop the engine. What happens?
,,,,When whatever stops, put the cap ON and start the engine. Blip for ~ 15 sec.
,,,,Stop and loosen the radiator cap with a rag. Was there any significant pressure buildup or barely a spit?
... These should tell us something in the course of just a few minutes. :confused3:
   / I'm admitting defeat---- Last time on this........... #38
A recovery tank may help save coolant till the problem is fixed. Siphoning back would seem to suggest a mis-assembled vs bad/leaking head gasket or a crack that closes as it cools, but that should show itself by spouting when running vs once stopped. I second B&D's ? as to whether there is a few minutes of cool-down regardless of operating cycle or load. Compression test might prove head gasket is ok if fluids aren't mixing.
My JD 1520 gas had a solenoid-type mixture adjusting gadget on the carb bowl that didn't seem to work right. There was a setting procedure that confounded interpretation and IIRC a limp home setting or spring & poppet that were installed in opposite order when it went awry. Seems it ran rich in the patch-up position vs lean despite getting power and drawing current when checked with a clamp-on tester. XS timing advance makes for knocking, delayed timing often causes lean running and that could be enough to cause 'cooking' after shutdown. Valve lash ok? I'd check that with the head still on as it can affect proper cyl scavenging and effective mixture.
Since I'm rambling from left field I'll add one thing I learned the hard way after replacing a part. Bad thermostat (worse symptoms that the OP's) has me buying them in pairs as a rule. I try 'em both before moving on to other checks or swaps. One acid rinse may not be enough, & I never liked closed circuit hydraulics, as I suspect the old 2020 may have, as they can work the engine more than is obvious if the unloader/bypass hangs up. Makes me wonder how hot the hydro oil gets and can it be checked with the point & shoot temp gun. I wouldn't assume that a few small things aren't adding up.
Sorry to just throw wild thoughts out, but I can be stubborn & tend to over-think things, as it has brought results. Prayers for the Mrs.
tog
   / I'm admitting defeat---- Last time on this........... #39
Brother you are not whining.. you are keeping the faith..so lets least options
Local Community college that might let you take it in as a class project...ours do here in NC.
Any friends willing to join in?
I know when it comes wood splitting time around here. All the families have cook outs while the men folk do the
splitting and the kids to the stacking..of course the Lady folk do the cooking so it is done right.
Never hurts to ask for help
   / I'm admitting defeat---- Last time on this........... #40
Actually Spyder I do like the idea of a gasket that was installed wrong and partially restricting flow. Some of the older stuff was just that way, one has to pay close attention in reassembly.
The biggest problem at this point is discounting all other options because you're never going to reproduce any of the classic symptoms of a bad head gasket.
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
UNKNOWN 16 T/A TRASH TRAILER (A52472)
UNKNOWN 16 T/A...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
