Another Trailer Build?
   / Another Trailer Build? #11
I wouldn't scrap it, I would like to stumble across something similar as I need a trailer to pull wood with my jeep.
I like that little case. I have a ctl70 rubber tracked skid steer but I need a small dozer for about a month.
   / Another Trailer Build? #12
Darn near had a heart attack. Saw the caption above the first pic and thought you were fixing to chop up the Case. I'd keep the frame and add a walking beam tandom axle. Then mount dump bed and lift system. Can't beat a walking beam in the woods.
   / Another Trailer Build? #13
How do the walking beam tandem axles do on the road at speed? How do you put shocks on them?
LOL how does the Case crawler do at road speed?
Had an idea about using 1/8" steel sheet for the tub then reinforcing the bottom for the lift cylinder. Also a tailgate that hinges down not up, like a pickup truck.
Still thinking, very bust this week making a living, Fred
   / Another Trailer Build? #15
If it were me. I'd fix it up because I love old things. lol
Gotta love that Taylor-Way beverage cooler/dispenser!
:thumbsup: I need me one of those.
Chad
So I pretty much have the frame stripped, by the time I'm done paying for grinding wheels, torch gas and Hypermax 600 consumables I might have been better off starting from scratch. I have a love hate relationship with Hypertherm right about now, I've never been totally satisfied with the maintenance and performance of this unit. Might be time to trade for a better model. It eats consumables and I don't have a lot of experience using it; could be part of the problem.
The only good parts are the frame and the axle. I think 2 small diameter dump cylinders should work ok, well I hope. I have this hair-brained idea to make this road-towable with lights and suspension. If so I need a way to lift the dump as my trucks don't have hydraulics.
I thought about making a small portable pump and reservoir by using a weed wacker motor and power steering pump from a car.
What say is that wacky or what?
I do have a Stihl KM-130 and a used power steering pump from a Q7 Audi :shocked: .
Watch out for the Fred he sounds dangerous!
   / Another Trailer Build? #17
Thnx for keeping us posted TF !
With what (very) little I know about hydraulics, I'd be tempted to start with something like this:
6.5 HP 196cc 2-Stage Hydraulic Power Unit | Princess Auto
(If link doesn't show up.... that's basically an integrated hydraulic power pack, w. 6.5hp gas motor @ $469 Canadian).
Couldn't find anything equivalent listed at Harbor Freight..... but knowing the typ. Canada/USA price splits, I'd be surprised if you'd spend much more than $300 to buy that new down your way.....
I've seen some amazing things built and working well, based on What was Lying Around...... so don't take this post as Don't Do It...... just my :2cents:
Rgds, D.
   / Another Trailer Build? #18
The power steering pump actually sounds pretty ingenious I've got an old cultivator tractor that runs the lift off a power steering pump and lots of guys have a hydraulic winch on the front of there truck that's plumbed to the power steering
   / Another Trailer Build? #19
How much pressure does a power steering pump generate? Have you thought about using an old push mower engine? I see people selling refurbished ones all the time for $10 to $20. You might need to by a pump and a lovejoy connector though.
One of these days I want to convert a 20' 12K flat bed trailer into a dual use trailer. I was going to make the deck removable so it could be swapped with a dump box. While not free I figured I would use a 2 stage wood splitter pump connected to a 5hp lawnmower engine. The pump, tank, and box would be removed as one unit. A wood splitter pump would allow it to dump at a good speed for lighter loads, say firewood while kicking down to dump the occasional load of gravel.
I would calculate the pressure and flow desired for the cylinders you plan on using and then see if the pump can produce what you can live with and then if the engine will have the HP needed for the job. No point in making something that could be great handicapped.
The flow of the car PS pump is low compared to tractor but pressure is similar. 1.9 horsepower might not be enough to turn the pump under pressure, I guess it's worth a shot to try it. I was thinking of keeping the pump and homemade reservoir separate that could be thrown in the back of a pickup truck to use when the tractor is not around, kind of portable power unit if you will. Also would need a valve body with two way valve.
It might not be worth the effort.
For now I need to concentrate on the hoist for the trailer, something cheap and reliable that would lift a run of wood.. Hmmmmmmm
Fred
Object moved
2010 FORD F550 XL SUPER DUTY SERVICE TRUCK (A57192)
2010 FORD F550 XL...
SCAN TO RECEIVE TEXT UPDATES (A57192)
SCAN TO RECEIVE...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
Informational Lot - Financing (A55314)
Informational Lot...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
