Radiator HELP!!!
   / Radiator HELP!!! #1
vwbusman66
Kingsville, MD
1952 Ford 8N
Okay so I have everything drained and flushed and I need to remove my radiator as it is beyond repair and sketchy as ****. I can't manage to understand how the **** I am supposed remove the two bolts on the bottom of the radiator. Any help is appreciated, James
   / Radiator HELP!!! #2
radiator...is beyond repair
It would certainly seem to increase your options if you aren't worried about damaging the radiator. Sawz-All? Cutting torch?
   / Radiator HELP!!!
Yeah... I tried to chisel the bolt that is rotating but it just gets wedged. Im not sure where to go now but I really want to avoid damaging the oem radiator. Whats a cutting torch?
   / Radiator HELP!!! #4
The 2 bolts are captive in the rad, you have to remove the 2 nuts underneath, when I messed with mine I found that I had to sort of pull (towards the front of the tractor) on the opposite side cause the captive bolt was spinning a bit.
   / Radiator HELP!!!
the issue is that the right one is spinning freely and I can't manage to get it locked to break or loosen the nut
   / Radiator HELP!!! #6
Okay, probably not an option.
Oxy-fuel welding and cutting - Wikipedia, the free encyclopedia
Not finding a good picture of it on-line. Can you get to the sides of the nut? Possibly a Dremel tool with a cutting wheel to cut the nut in half? or a Nut Splitter?
   / Radiator HELP!!! #7
Uh-oh!
you might not should own an old tractor if you don't know what the 3 main tools to fix them are!
welder
torch
hammer
   / Radiator HELP!!! #8
if the shouldered bolt head spins and you can't capture it, or leverage it down or lit on the radiator to leverag ehe bolt. then you will be cutting the bolt or splitting the head...
not many options available past that.
got a hacksaw blade?
   / Radiator HELP!!!
I own all three. Quick question, would it be possible for me to torch the bolt then take a chisel and try and whack the crap out of it
   / Radiator HELP!!! #10
if you can blow the nut off.. just do that and yo can get the rad out
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
Freighliner Tender Truck (A56438)
Freighliner Tender...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
Kubota M125X (A60462)
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
