OP
rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,165
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
More parts accumulating after being cut:
Thanks ...I'm always impressed when someone on here takes on a project of this scope.
It isn't really all that hard ... particularly with MIG ... a friend who is a welder showed/coached me.I have to learn to weld....
Yes ... I used your pictures along with NHBotanut's) when I was laying it out and modeling itI have the same W.R Long grapple, only wider.
Interesting that you should mention that ... as that was in the original design from a couple years ago ... the one I lost in the hard drive crash.The one suggestion I have would have is to add an additional angle to the lower jaw. It appears from your drawing that it is straight. It would increase your brush carrying capacity, put the "spades" on the lower jaw in a better rooting position and give you a better hold on whatever you are carrying.
Cool ...I handle lots of logs and for ease of picking them up it's a great design. Just drive up to the log, give it a little push to make sure it's resting on all the spades and close the grapple. It pulls the log into the lower angle every time.
Thanks !Here's a photo of what the lower angle looks like. Good luck and nice thread.
Yeah ... I welded the lower rake teeth on night before last i think ... but I can always modify it later if need beEdit: While typing this thread you posted lots of updates so it looks like you are past my suggestion.
Yeah ... that was a bit of a mind flock for me ...I am blindly gathering parts to make a grapple. I'm still stalled on what the geometry is for the cylinders to close.
Will do.I will be watching your build so keep posting.
SSQA ... but I still have to build the tractor side SSQAAre you making it qa or pin on?
I used 1/2" x 3" flat bar (upper jaw arms, rake teeth) ... but there's no reason 3/8" x 4" couldn't work, providing it's properly reinforced.I have gotten 2 4" square tubes and a bunch of 3/8 x4" flatbar.
Always handy to have around ...Looks like I need some sch 80 pipe.
