l235dt, all fluids changed now clutch pedal won't engage for pto
   / l235dt, all fluids changed now clutch pedal won't engage for pto #31
Sitting on the ground not bolted up the fingers will stick out much further and that gap will be greater.
Sitting on the ground not bolted up the gingers will stick out much further and that gap will be greater.
OK, I'm putting it all back together to see what happens...
   / l235dt, all fluids changed now clutch pedal won't engage for pto #33
One thing I'd suggest - the new clutch assembly may have been sitting around for a while and the pto disk may just be a little stuck to its faces, like a travel clutch can get when the tractor sits a while. Maybe connect a rotary mower to the pto and see if running with the pedal down will break it free ? May need to set it down on some brush or something to develop some whacks.
   / l235dt, all fluids changed now clutch pedal won't engage for pto #34
Good point, I hadn't thought of that, mostly because I've never replaced an entire assembly like that. I've always just replaced needed parts. I have the Kubota set-up jigs too so that makes things a bit easier.
I will give that a try
That didn't work.
I will re-check everything...maybe I will have to split the tractor again and disassemble the clutch pack.
Anything else I should check first?
2022 Massey Ferguson 1825E 4WD Tractor (A50860)
2022 Massey...
2007 Ford Crown Victoria Sedan (A50860)
2007 Ford Crown...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
