l235dt, all fluids changed now clutch pedal won't engage for pto
   / l235dt, all fluids changed now clutch pedal won't engage for pto #31
Sitting on the ground not bolted up the fingers will stick out much further and that gap will be greater.
Sitting on the ground not bolted up the gingers will stick out much further and that gap will be greater.
OK, I'm putting it all back together to see what happens...
   / l235dt, all fluids changed now clutch pedal won't engage for pto #33
One thing I'd suggest - the new clutch assembly may have been sitting around for a while and the pto disk may just be a little stuck to its faces, like a travel clutch can get when the tractor sits a while. Maybe connect a rotary mower to the pto and see if running with the pedal down will break it free ? May need to set it down on some brush or something to develop some whacks.
   / l235dt, all fluids changed now clutch pedal won't engage for pto #34
Good point, I hadn't thought of that, mostly because I've never replaced an entire assembly like that. I've always just replaced needed parts. I have the Kubota set-up jigs too so that makes things a bit easier.
I will give that a try
That didn't work.
I will re-check everything...maybe I will have to split the tractor again and disassemble the clutch pack.
Anything else I should check first?
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A50860)
2015 Top Hat T/A...
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
2000 Ford F150 (A49461)
2000 Ford F150...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
