l235dt, all fluids changed now clutch pedal won't engage for pto
   / l235dt, all fluids changed now clutch pedal won't engage for pto #31
Sitting on the ground not bolted up the fingers will stick out much further and that gap will be greater.
Sitting on the ground not bolted up the gingers will stick out much further and that gap will be greater.
OK, I'm putting it all back together to see what happens...
   / l235dt, all fluids changed now clutch pedal won't engage for pto #33
One thing I'd suggest - the new clutch assembly may have been sitting around for a while and the pto disk may just be a little stuck to its faces, like a travel clutch can get when the tractor sits a while. Maybe connect a rotary mower to the pto and see if running with the pedal down will break it free ? May need to set it down on some brush or something to develop some whacks.
   / l235dt, all fluids changed now clutch pedal won't engage for pto #34
Good point, I hadn't thought of that, mostly because I've never replaced an entire assembly like that. I've always just replaced needed parts. I have the Kubota set-up jigs too so that makes things a bit easier.
I will give that a try
That didn't work.
I will re-check everything...maybe I will have to split the tractor again and disassemble the clutch pack.
Anything else I should check first?
1981 Chevrolet P30 Box Truck (A50860)
1981 Chevrolet P30...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2021 Ford F-150...
2018 Nissan Versa Sedan (A48082)
2018 Nissan Versa...
2022 J&M 1151-22S Classic Grain Storm Grain Cart (A50657)
2022 J&M 1151-22S...
2010 Cadillac SRX SUV (A50860)
2010 Cadillac SRX...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
