Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors??
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #1
davefr
Member
Western Oregon
JD 1070
I converted my shop from Kerosene to Propane space heating and have about 15 gallons of surplus clean/fresh K1 Kerosene. I know Kerosene and Diesel are very closely related fuels. Can I gradually blend in some Kerosene with Diesel and use it up in my older JD's (ie 1070 and 455)? If so, what would be a safe/conservative ratio?
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #2
Yes you can, if you buy fuel in the winter in will often have kerosene blended in it already. I'd probably limit it to 20% kero but that's a guess on my part. Kero is a little "dryer" than diesel so you could blend it at a higher ratio but might want add something like 2 stroke oil.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #3
I have done that to use up extra kerosene as the salamander heater likes fresh fuel. But I only ran maybe 5% or so.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #4
Old Ford F-350 7.3 IDI diesel said in the owners manual that you could. It is out back but at 20% you would be safe in the truck.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #5
fine for winter blend ( flows better ) at up to 10 percent ... must add 2 stroke oil for lube to offset....
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #6
Yup, cut it this winter
Makes goods parts cleaner too
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #7
My winter mix is 3 gallons diesel, 2 gallons kero. If I have any space heater kerosene left in the spring, I put it in the tank a quart at a time to use up.
Will
Is there a rule of thumb for how much 2 stroke oil to add?
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #10
i think i'd go stanadyne or power service before 2 stroke oil.. if it was an on roader anyway.
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
