Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors??
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #1
davefr
Western Oregon
JD 1070
I converted my shop from Kerosene to Propane space heating and have about 15 gallons of surplus clean/fresh K1 Kerosene. I know Kerosene and Diesel are very closely related fuels. Can I gradually blend in some Kerosene with Diesel and use it up in my older JD's (ie 1070 and 455)? If so, what would be a safe/conservative ratio?
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #2
Yes you can, if you buy fuel in the winter in will often have kerosene blended in it already. I'd probably limit it to 20% kero but that's a guess on my part. Kero is a little "dryer" than diesel so you could blend it at a higher ratio but might want add something like 2 stroke oil.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #3
I have done that to use up extra kerosene as the salamander heater likes fresh fuel. But I only ran maybe 5% or so.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #4
Old Ford F-350 7.3 IDI diesel said in the owners manual that you could. It is out back but at 20% you would be safe in the truck.
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #5
fine for winter blend ( flows better ) at up to 10 percent ... must add 2 stroke oil for lube to offset....
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #6
Yup, cut it this winter
Makes goods parts cleaner too
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #7
My winter mix is 3 gallons diesel, 2 gallons kero. If I have any space heater kerosene left in the spring, I put it in the tank a quart at a time to use up.
Will
Is there a rule of thumb for how much 2 stroke oil to add?
   / Can I blend in some surplus Kerosene w/Diesel and use it up in my tractors?? #10
i think i'd go stanadyne or power service before 2 stroke oil.. if it was an on roader anyway.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
207278 (A52708)
207278 (A52708)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
