Any body built a knuckleboom loader
   / Any body built a knuckleboom loader #61
Why are so many small loaders for sale up north, and nothing but big loaders for sale in the south?
Are you looking in the right place? I found 4 cranes in 10 minutes of searching. 3 of them would probably be the right size.
Here is one in Youngsville NC for $1500: Palfinger/Hiab folding truck crane
Truck mounted one (with the truck) in Salisbury, NC for $2600: 1956 White 9000TD Flatbed Dump Truck W/ Crane - REDUCED (again)
Another truck mounted one (currently on a F600) in or near Mineral Springs, NC for $3000: Ford F600
Yet another truck mounted one for $3200 (might be a little small, its mounted on a Chevy 3500): 1992 Chevy 3500 with utility bed and crane
Aaron Z
I've seen those ads. Not really what I am looking for. Most of the folding truck cranes are to heavy to place on the tongue of a trailer. Now if you run across a farmi or similar I'm very interested.
   / Any body built a knuckleboom loader #63
If you could get that graveyard crane for closer to $1000 I think you'd be money and time ahead. You'd have a rotating base that's already been engineered for the job and you could re-use the hydraulic cylinders and valves.
   / Any body built a knuckleboom loader #64
That was my thought. The first or second ad could probably land you with the crane for $1000-$1200 (for the second, you would need to re-sell the truck without the crane for at least $1400 to get that, or use the frame to build a trailer). If the boom on the crane is too heavy, you could build your own boom, but you would be starting with outriggers, a rotating base, a valvebank and some cylinders.
Alternatively (if the mechanics crane is heavy enough), the Chevy 3500 could probably be had for $3000 and could be resold for $2000 (or $2500) without the crane. That crane would just need a high mount base to sit on.
Aaron Z
Yea, I considered it, but then I looked it up, it 360miles from me. A problem with using folding cranes with extendabooms is the hydraulics for the grapple. You either have to use a retracting hose reel or let the hoses dangle when the boom is retracted. I have used retractable cable reels attached to the hoses to keep them from hanging, so it doable, Takes 4 hoses for the rotator and grapple. I just dont see a $1000 value plus a day of travel time and expenses to get it. Now if it was across town and I could get a good look at it, I might have a change of heart.
I have actually seen the crane military truck in Salisbury NC, 240 miles, I used to work there. The f600 in Mineral Springs is just outside Charlotte NC, I will be out there next wk so might look it up.
Buying a used crane just to get the cyl, control valves, swivels, etc and then rebuilding the boom I dont know about that. Can I do it, sure, do I want to do it, I'll have to think about that one. I have been scrounging the scrap yards for a while now and already have a pile of valves and cylinders. Really, the swivel is all I need.
   / Any body built a knuckleboom loader #66
Good point, if you already have a valveblock, it doesn't make quite as much sense. If you are going to build the boom either way, you might be able to sell the boom portion of a knuckleboom to offset your costs. I imagine that it would be worth at least few hundred to the right buyer.
Aaron Z
I actually have a boom off a long arm mower I thought about using. Its a little short, but I got the cylinders for it and the valve bank. I probably wont use that entire boom because it is only 10ft, but I am thinking about using the root boom portion as a dipper boom on my loader. The dipper boom had a knuckle in the middle to allow the mower to kick back incase you hit something when mowing. I used the cylinders to make a small knuckle boom for my log spliter. it was strong enough to pick up the size wood I wanted at 14ft extended. To bad my swivel wasnt up to the task.
   / Any body built a knuckleboom loader #68
That's what I want to build for my new splitter, but with a hydraulic grapple.
Like this
   / Any body built a knuckleboom loader #69
Now that's a splitter.
   / Any body built a knuckleboom loader #70
Found this truck on Craigslist in hohenwald TN for $3000 or best offer come on down and we'll go in half and you can carry the boom home with you lol.
2021 BOBCAT T870 SKID STEER (A60429)
2021 BOBCAT T870...
2017 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2017 KOMATSU...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
