wmonroe
Elite Member
Call around to local diesel repair shops and see if they will test the injectors for you. From the sounds of it they might be due for a rebuild.
Another little tidbit. Before I installed my coolant thermostat and spout to the front of my engine, I had the idea to test it in a pan of boiling water because before I shut this tractor down when I had problems at the beginning of this thread, it seemed to be overheating also (but did not have a temp gauge on the tractor at the time to confirm it). Anyway the old Ford thermostat was closed so I figured the hot water should open it up. It does open, but not until after the water begins boiling. Then after it cools, it would not close again, but was stuck open. (glad I tested it). I figured a thermostat would be a cheap easy fix, but whoa Ford is proud of there thermostats - $40! I finally found a cross over number online to a Slant thermostat #13358 that is supposed to work for $5 that is on order.
if yuo get a compression fitting for the block, my advice is to NOT use an elbow.. but a straight one. make a sloping bend from it to the oil gauge. should work fine. Mine do.![]()
What problem was the elbow introducing?
