Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,231
Here's mine.
LS XR3037HC heated cab with Diamond 7 1/2' PA plow setup on 4 skid shoes. Also a 7 1/2' snow pusher blade.
   / Pictures of your snow weapons #2,232
Here's mine.
How do you find those "four" shoes working out for you?
   / Pictures of your snow weapons #2,233
My goal was that anything that I have that can fit the 3pt hitch on the rear will work on the front. ex: yard/rock rake now can be used on the front as well, subsoiler as well..great when ripping roots from a bank and then raking it..10400845_10152453735908961_7136754215269534620_n.jpg10511165_10152453736763961_4023804974421679059_n.jpg10527664_10152453736178961_8225968876176026480_n.jpg
Hmmm?
I don't have anything like that on my FEL. Is it a plow mount? Looks pretty heavy duty.
Only think I have on my FEL is a bucket or the JD forks.
I did modify the forks so they could be easily picked up with the iMatch quick hitch.
   / Pictures of your snow weapons #2,234
I'm hoping they will work well. I just put this setup together so haven't plow with it yet. It should ride on the shoes keeping the cutting edge from digging in when the ground isn't frozen. I saw this type setup on another members tractor plow build. Sitting on the shoes the cutting edge is 1/2" above the ground. If I plow a paved lot or driveway I can adjust the shoe levels to lower the cutting edge.
   / Pictures of your snow weapons #2,235
I've never seen this type of setup, let us know how this work's, will you,,
it looks very interesting and make sense.
   / Pictures of your snow weapons #2,237
A piece of slit pipe over the cutting edge.
Mine was like 1.5" thin-wall steel pipe.
PVC might hold up for a season, I dunno.
I've heard that pvc is too brittle in the cold weather. I've used ABS pipe on both my bucket and blade. I need a new one on my bucket and it won't be long until the one on my blade needs to be replaced also. But I got a season out of the blade and 1 1/2 on the bucket, all for $10.
   / Pictures of your snow weapons #2,238
A little closer to being ready. It's in the shop at work for a couple enhancements and paint. The skids have an added 3/8" of wear bar stitched on. The chute mechanisms have been modified so the up/down will be done with a linear actuator, and left/right will be done with a motor. Hope to get it painted early next week. Wiring is done and tested on the tractor end.
   / Pictures of your snow weapons #2,239
Nice, do you think that motor will be strong enough to rotate the shoot.
   / Pictures of your snow weapons #2,240
Sure hope so. The motor is in the link below. I couldn't slow it down trying to hold it back. Should have it together to try it within the next two weeks. The paint is a catalyzed enamel and has a 7-day cure time.
CAR SEAT 3-12VDC GEAR MOTOR
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A55852)
2015 International...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
