Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,231
Here's mine.
LS XR3037HC heated cab with Diamond 7 1/2' PA plow setup on 4 skid shoes. Also a 7 1/2' snow pusher blade.
   / Pictures of your snow weapons #2,232
Here's mine.
How do you find those "four" shoes working out for you?
   / Pictures of your snow weapons #2,233
My goal was that anything that I have that can fit the 3pt hitch on the rear will work on the front. ex: yard/rock rake now can be used on the front as well, subsoiler as well..great when ripping roots from a bank and then raking it..10400845_10152453735908961_7136754215269534620_n.jpg10511165_10152453736763961_4023804974421679059_n.jpg10527664_10152453736178961_8225968876176026480_n.jpg
Hmmm?
I don't have anything like that on my FEL. Is it a plow mount? Looks pretty heavy duty.
Only think I have on my FEL is a bucket or the JD forks.
I did modify the forks so they could be easily picked up with the iMatch quick hitch.
   / Pictures of your snow weapons #2,234
I'm hoping they will work well. I just put this setup together so haven't plow with it yet. It should ride on the shoes keeping the cutting edge from digging in when the ground isn't frozen. I saw this type setup on another members tractor plow build. Sitting on the shoes the cutting edge is 1/2" above the ground. If I plow a paved lot or driveway I can adjust the shoe levels to lower the cutting edge.
   / Pictures of your snow weapons #2,235
I've never seen this type of setup, let us know how this work's, will you,,
it looks very interesting and make sense.
   / Pictures of your snow weapons #2,237
A piece of slit pipe over the cutting edge.
Mine was like 1.5" thin-wall steel pipe.
PVC might hold up for a season, I dunno.
I've heard that pvc is too brittle in the cold weather. I've used ABS pipe on both my bucket and blade. I need a new one on my bucket and it won't be long until the one on my blade needs to be replaced also. But I got a season out of the blade and 1 1/2 on the bucket, all for $10.
   / Pictures of your snow weapons #2,238
A little closer to being ready. It's in the shop at work for a couple enhancements and paint. The skids have an added 3/8" of wear bar stitched on. The chute mechanisms have been modified so the up/down will be done with a linear actuator, and left/right will be done with a motor. Hope to get it painted early next week. Wiring is done and tested on the tractor end.
   / Pictures of your snow weapons #2,239
Nice, do you think that motor will be strong enough to rotate the shoot.
   / Pictures of your snow weapons #2,240
Sure hope so. The motor is in the link below. I couldn't slow it down trying to hold it back. Should have it together to try it within the next two weeks. The paint is a catalyzed enamel and has a 7-day cure time.
CAR SEAT 3-12VDC GEAR MOTOR
pressure washer (A55973)
pressure washer...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
2020 Mathieu MC210 Azura Flex Street Sweeper (A55851)
2020 Mathieu MC210...
AUCTION STARTS HERE @ 9AM (A52707)
AUCTION STARTS...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A55314)
2023 Kubota Z412KW...
