pros and cons to running a 4WD tractor in 2WD
   / pros and cons to running a 4WD tractor in 2WD #61
A flatlander may get away with 2 by but on the hills you're just asking for trouble- as others say.
In the MS Delta its all flatland! Having a 4WD is almost mandatory in that gumbo if you gonna get any tractor work done!
   / pros and cons to running a 4WD tractor in 2WD #62
There is no real difference between 2wd v 4wd on your tractor or on your pick'm up truck. I'm in 2wd until I start loosing traction in 2wd. Then I'm in 4wd. When I regain traction on more solid ground, I switch to 2wd. Less wear and tear, less fuel, better turning radius.
   / pros and cons to running a 4WD tractor in 2WD #63
SAME FOR ME>
   / pros and cons to running a 4WD tractor in 2WD #64
SAME FOR ME>
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA (A55745)
2016 FREIGHTLINER...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
