pros and cons to running a 4WD tractor in 2WD
   / pros and cons to running a 4WD tractor in 2WD #61
A flatlander may get away with 2 by but on the hills you're just asking for trouble- as others say.
In the MS Delta its all flatland! Having a 4WD is almost mandatory in that gumbo if you gonna get any tractor work done!
   / pros and cons to running a 4WD tractor in 2WD #62
There is no real difference between 2wd v 4wd on your tractor or on your pick'm up truck. I'm in 2wd until I start loosing traction in 2wd. Then I'm in 4wd. When I regain traction on more solid ground, I switch to 2wd. Less wear and tear, less fuel, better turning radius.
   / pros and cons to running a 4WD tractor in 2WD #63
SAME FOR ME>
   / pros and cons to running a 4WD tractor in 2WD #64
SAME FOR ME>
1978 KENTUCKY TRAILER MFG 53 DRY VAN TRAILER (A55745)
1978 KENTUCKY...
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A55745)
2014 AMERITRAIL...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2018 John Deere 1653 (A55314)
2018 John Deere...
