pros and cons to running a 4WD tractor in 2WD
   / pros and cons to running a 4WD tractor in 2WD #61
A flatlander may get away with 2 by but on the hills you're just asking for trouble- as others say.
In the MS Delta its all flatland! Having a 4WD is almost mandatory in that gumbo if you gonna get any tractor work done!
   / pros and cons to running a 4WD tractor in 2WD #62
There is no real difference between 2wd v 4wd on your tractor or on your pick'm up truck. I'm in 2wd until I start loosing traction in 2wd. Then I'm in 4wd. When I regain traction on more solid ground, I switch to 2wd. Less wear and tear, less fuel, better turning radius.
   / pros and cons to running a 4WD tractor in 2WD #63
SAME FOR ME>
   / pros and cons to running a 4WD tractor in 2WD #64
SAME FOR ME>
2020 Deere 50G (A53317)
2020 Deere 50G...
GODWIN 3,500 PSI HYD. POWERPACK (A55745)
GODWIN 3,500 PSI...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
1837 (A51248)
1837 (A51248)
16FT box truck (A53424)
16FT box truck...
2014 Nissan Pathfinder SUV (A55853)
2014 Nissan...
