Where did you place the antenna? In the attic? In the house?
in the house beside the main tv, i either prop it up against the wall, or set it up on a cabinet. the extra length on bottom lets me place it behind other objects on cabinet and not get hung up on crud. or set it behind a floor speaker.
with aluminum siding, and tv stations spread out far enough apart, and living out in middle of no were. i do have to move the antenna. for some stations more so bad weather. and trying to get them stations clear away from me, that i would not normally get with some store bought antenna.
i also have a piece of plywood with aluminum foil (kitchen foil ya use for cooking) on one side. ((need to make sure wrinkle free)) that i can place behind it. to focus everything better. with the 2x6 lumber that the hangers are attach to. it holds the wires off just enough from the foil. and seems to work pretty good. but i have for most part abandoned the aluminum foil on plywood. due to only extra channels i pick up. are exact same "copy" channels per say but from another large city. (different news, but same shows doing), to also note it, the aluminum foil on plywood can cause interference on certain stations, it causes to much single bouncing around in home.
it would be nice to place this homemade antenna up in the attic or up on the roof. but i would still want to be able to rotate it some.
the home made antenna and foil on plywood, i have tried at my mom's house, and at a cabin back on the farm. both in basement, main level, and roof. and the home made antenna has won, vs all other antennas i have tried. with exception like noted before. a roof mounted antenna. that can rotate more likely to win out vs anything out there.
