Mounting a PTO hydraulic pump
   / Mounting a PTO hydraulic pump #1
dgarrett
Member
Kitsap WA
Kabota B2320 Narrow
Hi,
I need to mount a cast iron Prince PTO pump on to my PTO shaft. Should I let it hang off the shaft with a torque bar and chain holding it or should I make a bracket and firmly mount it to either the draw bar or tractor chassis?
Thanks
   / Mounting a PTO hydraulic pump #2
many hang it with a torque bar,
If I would mount it, and attach it to the frame of the tractor, Not the draw bar,
   / Mounting a PTO hydraulic pump #3
Hi,
Thanks
They are designed to hang from the shaft and anchor with a torque bar and chain. Been that way for 40 years or more. It will work well that way.
   / Mounting a PTO hydraulic pump #4
My 4 roller sprayer pump, same thing but different:
Edit: For some reason I can get it to show as a thumbnail like usual??
   / Mounting a PTO hydraulic pump #6
Agree with Rick. The bearings on the pump don't want to be constrained. Since the whole rig will want to wobble a bit, you should let it.
Thanks for the help
It's a Kabota b2320 narrow. I need to remove the PTO shroud and still might need to add a PTO coupler to extend the shaft away from the tractor in order to fit the pump. If I do, I most certainly will need to hard mount it to something.
   / Mounting a PTO hydraulic pump #8
What kind of hydraulic load? The factory pump is respectable for a tractor it's size. 4.7gpm to the SCV and 8.3gpm if the power steering isn't hogging some flow.
Is the tractor missing the optional SCV?
Yes, I need more flow, I am going to turn a couple of motors for extended period of time at 12GPM. Also the tractor only has < 4 gallons of fluid.
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
