Mounting a PTO hydraulic pump
   / Mounting a PTO hydraulic pump #1
dgarrett
Kitsap WA
Kabota B2320 Narrow
Hi,
I need to mount a cast iron Prince PTO pump on to my PTO shaft. Should I let it hang off the shaft with a torque bar and chain holding it or should I make a bracket and firmly mount it to either the draw bar or tractor chassis?
Thanks
   / Mounting a PTO hydraulic pump #2
many hang it with a torque bar,
If I would mount it, and attach it to the frame of the tractor, Not the draw bar,
   / Mounting a PTO hydraulic pump #3
Hi,
Thanks
They are designed to hang from the shaft and anchor with a torque bar and chain. Been that way for 40 years or more. It will work well that way.
   / Mounting a PTO hydraulic pump #4
My 4 roller sprayer pump, same thing but different:
Edit: For some reason I can get it to show as a thumbnail like usual??
   / Mounting a PTO hydraulic pump #6
Agree with Rick. The bearings on the pump don't want to be constrained. Since the whole rig will want to wobble a bit, you should let it.
Thanks for the help
It's a Kabota b2320 narrow. I need to remove the PTO shroud and still might need to add a PTO coupler to extend the shaft away from the tractor in order to fit the pump. If I do, I most certainly will need to hard mount it to something.
   / Mounting a PTO hydraulic pump #8
What kind of hydraulic load? The factory pump is respectable for a tractor it's size. 4.7gpm to the SCV and 8.3gpm if the power steering isn't hogging some flow.
Is the tractor missing the optional SCV?
Yes, I need more flow, I am going to turn a couple of motors for extended period of time at 12GPM. Also the tractor only has < 4 gallons of fluid.
2007 Yamaha Rhino 660 (A55302)
2007 Yamaha Rhino...
2018 MITSUBISHI OUTLANDER SPORT (A55745)
2018 MITSUBISHI...
43030 (A51691)
43030 (A51691)
2004 Ford F-250 4x4 Service Truck with Liftgate (A55788)
2004 Ford F-250...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
UNUSED IRGC80 Battery Powered Golf cart (A47477)
UNUSED IRGC80...
