Mounting a PTO hydraulic pump
   / Mounting a PTO hydraulic pump #1
dgarrett
Member
Kitsap WA
Kabota B2320 Narrow
Hi,
I need to mount a cast iron Prince PTO pump on to my PTO shaft. Should I let it hang off the shaft with a torque bar and chain holding it or should I make a bracket and firmly mount it to either the draw bar or tractor chassis?
Thanks
   / Mounting a PTO hydraulic pump #2
many hang it with a torque bar,
If I would mount it, and attach it to the frame of the tractor, Not the draw bar,
   / Mounting a PTO hydraulic pump #3
Hi,
Thanks
They are designed to hang from the shaft and anchor with a torque bar and chain. Been that way for 40 years or more. It will work well that way.
   / Mounting a PTO hydraulic pump #4
My 4 roller sprayer pump, same thing but different:
Edit: For some reason I can get it to show as a thumbnail like usual??
   / Mounting a PTO hydraulic pump #6
Agree with Rick. The bearings on the pump don't want to be constrained. Since the whole rig will want to wobble a bit, you should let it.
Thanks for the help
It's a Kabota b2320 narrow. I need to remove the PTO shroud and still might need to add a PTO coupler to extend the shaft away from the tractor in order to fit the pump. If I do, I most certainly will need to hard mount it to something.
   / Mounting a PTO hydraulic pump #8
What kind of hydraulic load? The factory pump is respectable for a tractor it's size. 4.7gpm to the SCV and 8.3gpm if the power steering isn't hogging some flow.
Is the tractor missing the optional SCV?
Yes, I need more flow, I am going to turn a couple of motors for extended period of time at 12GPM. Also the tractor only has < 4 gallons of fluid.
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
