OP
sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,729
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
The plug change was easy yesterday and yeah, I did over engineer things. But I had never changed plugs in anything with aluminum heads and didn't want to screw it up. Anyway, the old plugs came right out and the new ones went right back in. I torqued accordingly but the simple extra twist after the crush washer contacted the head would have worked fine. In any event, it's done.
The old plugs were laser iridium with 96,000 miles and looked worn. The gap had opened considerably on some of them and there was some metal deposit on the ground wire portion of the plug. Heat and combustion looked as they should. Now lets see if the mileage improves since it had dropped off recently.
I have a follow up question. On the IR plug box there was a noticeable warning not to re-use the crush washers. That's a given. But does this also mean you cannot remove and reinstall an IR plug in the same hole or do you need to use a new washer/plug? Stupid question but would that apply to checking the plugs in any aluminum head engine or is this just the typical warning that's been on plug boxes forever or a special warning for aluminum heads? Can you remove and reinstall the same plugs in an aluminum head?
