I need help deciding on new trailer
   / I need help deciding on new trailer #61
I like that 20 ' flat deck what is the axel rating. That looks like a 2/3-1/3 axel split. I'm thinking I would prefer more like 60/40 for less tongue weight. What do you think?
I think you may be splitting hairs here between 60% and 67%. Why not just buy the trailer a couple feet longer than you need to squeeze everything on and you should be able to balance the weight the way you desire; and the extra length will be handy when hauling bulky or long items. I assume you're not meaning that even 800 lbs tongue like schmism has is too much and/or you're not averse to using a WD hitch such as he is doing.
   / I need help deciding on new trailer #62
My trailer is 6 bolt axles. 5200-6000 lb (depending on springs).
If you look at a PJ trailer, there 6" frame is listed as an equipment trailer with 7K axles (8 bolt) the 4 and 5" frame is listed as a car hauler with 5200 lb 6 bolt axles.
I dont see how you could get away with less tongue weight. The standard rule is 10% of the weight behind you. a 20' flat PJ trailer is 2000lbs curb weight your tractor plus backhoe has to push 5K more if you have loaded tires. thats 7000 lbs behind you at that point, which is 700lbs tongue weight.
I might run mine a bit heavy at 800lbs if i just have 5000lbs behind me, but honestly the 1 ton springs on my van like the weight.
   / I need help deciding on new trailer #63
Actually 2,000 lbs is the weight of the 7k rated trailers. Since he is looking to upgrade to at least 10K the weight will be closer to 3,000 lbs, and a 14K will be over 3000.
That's what I meant when I said I was assuming he wasn't trying to go less than 800 lbs tongue with a 10K+ trailer. I see you have a van, they can take a little more tongue weight since the overhang is generally shorter.
You may be right down slope I also like your idea about a longer trailer and I appreciate your response. I have put a lot of thought into this before I pull the plug on a new trailer. It just seems that with the 67% versus 60% split especially on dovetail optioned trailers it does not leave you much space for adjustment most of your weight has to be forward of the axles and it's very easy to get very heavy on tongue weight. I do have a weight distribution hitch have used it before but would prefer not having to have to use it. I have a halfton truck that I pull with and it does a very good job until the tongue weight gets excessive.most of my pulling his short distances.
   / I need help deciding on new trailer #65
I recently ordered a trailer from Load Max or Load Trail. Currently we have 4 trailers of varying sizes and capacities as well as designatations, but keeping up with registration, maintenance, inspection stickers, and worse, tires, is expensive and sometimes not completly followed through with. My plan is to use one trailer in place of the 4 I have now. The new trailer ordered is a model GR16, it has a hyd dove tail, 2 8K EOHyd disc brakes with 17.5 16 ply tires, deck on the neck, and 26' deck length. As a previous member had stated earlier this manufacture has a lot of details for the dollar. True it all adds up, but I've learned the hard way about under built trailers and repairs, and more so with under powered magnet brakes not stopping my load in time for aggressive drivers who dart in front of you and stop to turn. When the trailer comes in and in my possession, I will post some pics of it.
   / I need help deciding on new trailer #66
Check out Sure-Trac trailers. I bought an 18' w/radials, spare, removable fender, diamond plate bed, 7k jack and rated for 10k. The trailer is powder coated, frame constructed with tubing, excellent welds, all led lighting, sealed harness, etc. I loaded my tractor and additional attachments at very close to the trailer weight limit and it tows like a dream. It's almost like you don't have a trailer hooked up.
The pricing iis very competitive and I was all in at a little over 3.5k. No, I don't work for them or have any affiliation. I just have never seen anything about these awesome trailers on tbn.
FWIW, I purchased mine from 'The Hitchman' in Maryland. Great place with good, friendly, honest staff.
I live a few miles from where they are built, and the local dealer seems to be a few hundred $$ above remote dealers.
They are well built trailers in my humble opinion, I just find it difficult to pull the trigger when I know these guys are getting paid a premium
   / I need help deciding on new trailer #67
I had a very nice premier trailer 10,000 heavy-duty landscape trailer. Best trailer i ever had
Just sold my old trailer this weekend so now I'm kind of committed. Still using my friends 14 K for now but have not had to hall yet. As of now I'm thinking 20 foot 10 K car hauler.
   / I need help deciding on new trailer #69
With a 20' trailer I would not go with a 10K. Spend a few more dollars and get a 12K. It shouldn't weigh more than 50# more. Usually the only difference is the coupler, tires, wheels, and axles. Everything else is the same.
Chris
   / I need help deciding on new trailer #70
Chris
I can't speak for the OP, but I am also shopping for a 20', 10k# trailer. In my case it just doesn't make sense to step up to 12k# trailer.
The 10k# already has way more capacity than I'm likely to ever need. My tractor weighs 2000# before the FEL or implements. I don't know what the loader with the bucket weighs, but figure 1000#. Another ~700# for my flail mower, ~600# for the box scraper, take the forks along and that might be another ~3-400# (probably not that much on this little tractor). All that adds up to around 4300#. A 10k# trailer that weighs 3000# will have 7000# of capacity. I could load my tires, pack up all those implements, and still take a full ton of rocks with me.
In my case, I could easily get by with an 18', 7k# car trailer. A 20', 10k# tilt trailer is already my overkill. It all comes down to what you need.
2014 TRAIL KING JBTR-38 (A55745)
2014 TRAIL KING...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
1989 CATERPILLAR 963 CRAWLER LOADER (A52707)
1989 CATERPILLAR...
