Kubot MX5200 vs MX4800
   / Kubot MX5200 vs MX4800 #11
Actually, the non-adjustable ends would likely work better with a quick hitch.
You can buy the "Pat's" style aftermarket adjustable ends if you were so inclined. It can cause other connection issues
so read up on it first.
Yeah, I have Pats on one tractor. So-so in my book.
   / Kubot MX5200 vs MX4800 #13
(extendable 3pt arms). If there is an aftermarket mfg for these, I sure would like to know.
From the Kubota website:
3-Point Hitch
The powerful Category II 3-Point Hitch is convertible to Category I easily handles correctly matched Implements. Rigid link ends are standard on the MX4800 and MX5200F models, with telescoping link ends and stabilizers on the MX5200 and MX5800 4WD models, such a great feature. An upgrade kit is available for the MX4800 and MX5200F 2WD models. The telescoping lower links make hooking up and working with large implements easier.
Mid-Size Tractors | MX4800 MX5200 MX5800 | Kubota Tractor Corporation
   / Kubot MX5200 vs MX4800 #14
I can't imagine what kind on an upgrade kit you could get for the rear arms. Pat's is all I can think of unless you replace the arms.
EDIT---Wait a minute. Do the lift arms on the 5200 look longer overall than the 4800? Could it be that Kubota's 5200 arms are sort of built with a Pat's type system built in? Or Pat's has a Kubota system built in? Anyone know?
   / Kubot MX5200 vs MX4800 #15
I can't imagine what kind on an upgrade kit you could get for the rear arms..... unless you replace the arms.
That is what I was referring to (replace the arms). Aftermarket may be lower cost than Kubota.
   / Kubot MX5200 vs MX4800 #16
I have never seen aftermarket lift arms. It would seem they are too specific to the application and there would be no such thing as a universal model. Life's not too bad with regular lift arms. I have an MX5100 with the new style lift arms and I rarely use the extendable portion to hook up. Maybe one time out of 15 hook ups. Only use with really heavy and awkward items.
Another option is to find a junkyard model that would fit such as an MX5000 or 5100. I'll bet there are some 5000's being parted out now.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2019 GALYEAN...
