Can you back drag, or back rake effectively with a dual hydraulic grapple?
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #2
I back drag with my skid steer rake all the time, usually with the grapple down for better visibility. Mine does have a 3 inch pipe about 10 inches up from the tine points.
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #3
It works awesome. I do it all the time. mine has 2 clamps and 2 teeth each. They are on one line so they can raise and lower independently to grab an uneven object like a stump but for back dragging they just level out. 4 teeth is all you need for bushy scrubby stuff usually. it doesn't take much to grab the whole pile.
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #4
The only time I back drag is when the job is done and I'm dressing things up. Not too long ago a friend asked me what disc I used to finish a field. There was no disc, only back dragging with the grapple.
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #5
Compared to a typical rake grapple that has one lid and many tines, a typical 2 lid L grapple with only 4 tines will not back rake worth a dang. But they can do an "okay" job.
What are you trying to back rake?
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #6
It will not do dirt, but pulling brush backwards works really well.
Limbs, woody debris, roots from a clear cut
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #8
A Landscape Rake on the back of your tractor is a great compliment to a grapple for finishing, cleaning up fine debris.
Travis
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #9
   / Can you back drag, or back rake effectively with a dual hydraulic grapple? #10
2013 Ford F-550 Ambulance (A55788)
2013 Ford F-550...
2018 TAKEUCHI TB240 EXCAVATOR (A52705)
2018 TAKEUCHI...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2021 BOBCAT T870 SKID STEER (A52705)
2021 BOBCAT T870...
10' FIELD CULTIVATOR W/ ROLLING BASKETS (A54756)
10' FIELD...
