Very Frustrated :( Massey GC1720 vs BX25 Questions.
   / Very Frustrated :( Massey GC1720 vs BX25 Questions. #31
The numbers below are from the manufacturers' websites and spec. sheets. It took a bit of perusal to find equivalent numbers. I was unable to find any information about power at intermediate lift heights, i.e. at one foot above the ground. Keep in mind, the geometry of the loader affects the lift capacity at various heights. This geometry difference could possibly be reflected by Kubota's slightly higher breakout force, and MF's slightly higher lift to full height.
The values for the MF DL100 loader were mentioned above and are a bit lower than the numbers for either the DL90 or the BX25D so are not included.
MF DL95 LOADER and BX25D LA240A LOADER
DL95: Lift Capacity to Full Height @ 19.6 inches Forward of Pivot Pin: 580 lbs........... BX25D LA 240A Loader @ 19.68 inches: 518 lbs
DL95: Breakout Force @ 19.6 inches forward of pivot pin: 920 lbs........................... BX25D LA 240A Loader @19.68 inches: 992 lbs
Interestingly enough, this is where the games can be played.
DL95:Rated Hydraulic Pressure: 1914 PSI........................................................... BX25D LA 240A Loader: 1778 psi
If the system hydraulic pressure on the Kubota is changed to the same pressure as the DL95, the lift capacity to full height would be almost exactly the same.
It is my personal opinion, and importantly, my opinion only, that the manufacturers set lift capabilities based not on the mechanical capabilities, but on the consideration of machine stability.
The max lift of either of these machines could be easily increased, but the stability of the tractor would be negatively affected. The front axle is on a pivot so it offers little lateral stability. When a heavy load is lifted, the rear wheels become light, and with an extreme load, would actually lift from the ground. Capsizing is a real possibility. Since these tractors weights are approximately the same, I think the lifting power of either is appropriate and is not significantly different.
Both are very fine, well built and capable machines.
   / Very Frustrated :( Massey GC1720 vs BX25 Questions. #32
Take a look at this site they offer a loader quick hitch for Kubota, Cub Cadet, Kioti with grapple attachment and other loader attachments.
I think the price for the loader hitch was around $800.
MASSEY TACH-N-GO
MASSEY TACH-N-GO
I just ordered my BX25D tonight.
   / Very Frustrated :( Massey GC1720 vs BX25 Questions. #34
Congratulations. I think you'll love it.
As others have said, it will have its limitations but you will find ways to work around it. I doubt you'll have any trouble lifting the rocks in your pics, but there's no way you'll grab one of those slabs of concrete with a grapple and tote it off. But you could lift it enough to wrap a chain around it and drag it somewhere that it can be broken into BX-sized chunks.
Be very careful trying to drag that dock out of the water. If you get it part way out and lose traction, it could slide back in the water and drag you and the tractor back with it.
Thanks Pappy.
   / Very Frustrated :( Massey GC1720 vs BX25 Questions. #36
He makes a good point, the BX does a lot of things well but floating is not one of them
   / Very Frustrated :( Massey GC1720 vs BX25 Questions. #38
If I only could keep one tractor it would be my BX23
That said loaded or in my case foam filled rear tires made a big difference in stability all around.
Also, found my hydraulic pressure was about 12% low and when I set it to spec it was a noticable improvement on lift and breakout.
My favorite and least expensive implement has been the toothbar... really worthwhile when working banks.
Just remember the small TLB can be tippy...
I'm late to the conversation and was going to suggest you rent a BX25 from Home Depot... they don't rent them in California and was surprised they had two at the Lacey WA Home Depot last time I was there for rent...
PS... don't know about the 25 as far as a soft underbelly... I added a belly pan to my BX and I know it has saved me...
   / Very Frustrated :( Massey GC1720 vs BX25 Questions. #39
"My bucket floats!" Oh, that's good!
Informational Lot - Financing (A56436)
Informational Lot...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
