Bevelling Steel Pieces for Welding
   / Bevelling Steel Pieces for Welding #41
Stacking 2 X 2 X 1/4 doesn't sound like fun. Might take a better saw vice than typical.
I suppose one could tack them all together into a solid. That would be fast, that's for sure.
   / Bevelling Steel Pieces for Welding #42
Just need a shim of appropriate thickness in the back side of the moveable jaw.
2x2" isn't big enough to worry about though. Grinder will bang those out in no time.
   / Bevelling Steel Pieces for Welding #43
Let's think
2X2X1/4, a stack of even four would have less than an inch clamped for the top piece, and more than an inch overhanging to the saw blade.
That would take a pretty fair saw vise from my experience. Better than most I've seen on laydown cut off saws. True, the top piece would receive support from the pieces below. I wouldn't trust the set up with the Marvel 6X12
Regarding the use of abrasive methods, We share in that opinion!
   / Bevelling Steel Pieces for Welding #44
Some of it looks like more fun, but all methods thus far would be more time & trouble than a 9" grinder, and maybe even a 4 1/2". The most productive $$ thrown at the problem could be to buy a few vises, so you can get them all pre-clamped & setup before grinding.
   / Bevelling Steel Pieces for Welding #45
Let's think
Use a backer to extend the fixed jaw's reach and you have 1 full inch or more of clamping surface beneath all 4 parts - which is 50% of the surface area of the part and 400% of the cut's length across each part. It's a trivial set up. No tack welding needed.
Grinder is still going to be faster than band sawing through a 2x1" (effective) bar.
   / Bevelling Steel Pieces for Welding #46
On the whole I don't bevel 1/4" thick material, but it depends on what it's used for.
Personally I would clamp each piece to my welding table with a pair of #11s, and walk right down the line with a 9" grinder to bevel the plates.;)
   / Bevelling Steel Pieces for Welding #47
I guess you pulled your hand back down.
I knew you would come up with a good idea. My welding table is 40" long and I have at least 12 clamps of various types, A piece of flat bar on top and one clamp would hold 2 pieces. When I get back from vacation I now have a bunch of options I did not think of. In retrospect I should have cut each piece 1/16 th short and just gapped 1/8. actually this frame will take a lot of stress so wanted to assure good welding.
Thanks a lot guys, Ron
   / Bevelling Steel Pieces for Welding #49
If you already have the 1/4" stuff cut, a 9' grinder will work as fast as any thing mentioned so far and likely be better. Unless you have a very high dollar saw like Shieldarc, you likely wont get a good square cut and end up grinding anyway. If you double V bevel on the 1/4" stuff there is very little material to remove. I would double bevel all pieces to help control warping from welding. Even the 1/2" stuff isn't that difficult to do.
The best would have been to cut / bevel in one pass with a track torch (but who has one other than ShieldArc), second would be some kind of band saw or carbide bit saw (again ShieldArc has the tool).
For me since I don't have a million dollars worth of fancy tools, my 9" grinder with a Norton or Pipeliner grinding disc would get the job done fast.
Just thought I would throw this in since we are discussing bevelling metal. I use my 4.5" grinder with a TigerPaw sanding pad for cutting bevels on lawn mower blades. They work about as fast as a hard abrasive disc but don't overheat the metal. The only draw back is the cost at around $10-15 per disc.
   / Bevelling Steel Pieces for Welding #50
My friend is a retired master pipe fitter, he bevels that kind of stuff with a cutting torch.
I am always amazed by how smooth, and neat it is, when he does that.
When I try it, I end up pulling out the heavy duty 9" grinder.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
378721 (A54865)
378721 (A54865)
MISC RACK W/ALUMINUM & SICKER RODS (A55745)
MISC RACK...
1065 (A53342)
1065 (A53342)
1999 Vermeer SC505 Walk-Behind Tracked Stump Grinder (A55851)
1999 Vermeer SC505...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
