Any dual Cat1/Cat2 quick attach hitches?
   / Any dual Cat1/Cat2 quick attach hitches? #11
If you can't find a Priefert, the next closest in function may be Pat's Cat 2 on the tractor and bushings to match on the Cat 1 implement.
Pats Easy Change 3 Point Hitch System
Bruce
   / Any dual Cat1/Cat2 quick attach hitches? #13
   / Any dual Cat1/Cat2 quick attach hitches? #14
I wonder why more tractor companies don't do this. Our old Oliver 770 had offset bottom links on the 3 point which looked like the ends of a Pat's. If the offsets were in it was a cat 1, if they were out it was a cat 2. The top link connected to the tractor with a wishbone which had several holes in metal plates so you could move the top link up and down. 4 pins and you could change from a cat 1 to a cat 2, the process took about 2 min.
On a side note I never knew that normal cat 1 and cat 2 hitches didn't come with a Pat's style of catch until I got my John Deere.
   / Any dual Cat1/Cat2 quick attach hitches? #16
Yes I did.
And I looked at the picture.
And I noted your statement that they used to make that product.
Oh, I just LOVE the nitpicking!!! I never said someone USED to make the product, that was another poster (BukitCase).
In fact, LandPride still makes the product in the link in post #8. Unfortunately, it won't work on a 3PH. :stirthepot:
The poor OP asks a simple question, some people try to help out, and it results in an exercise in semantics. :eek:
   / Any dual Cat1/Cat2 quick attach hitches? #17
I thought semantics was navy jargon.
BRuce
   / Any dual Cat1/Cat2 quick attach hitches? #18
   / Any dual Cat1/Cat2 quick attach hitches? #19
Don't most of the cat 1 quick hitches have cat 2 sized hooks and require bushings to fit properly anyway?
   / Any dual Cat1/Cat2 quick attach hitches? #20
Some even have CAT3 hooks.
But the problem is the rigid frame. If the QH is set to CAT 1 width, then that is all it will accept. All implements have to be modified to the CAT 1 standard.
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2007 JLG 600S SKYPOWER TELESCOPIC MANLIFT (A51246)
2007 JLG 600S...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
