Any dual Cat1/Cat2 quick attach hitches?
   / Any dual Cat1/Cat2 quick attach hitches? #11
If you can't find a Priefert, the next closest in function may be Pat's Cat 2 on the tractor and bushings to match on the Cat 1 implement.
Pats Easy Change 3 Point Hitch System
Bruce
   / Any dual Cat1/Cat2 quick attach hitches? #13
   / Any dual Cat1/Cat2 quick attach hitches? #14
I wonder why more tractor companies don't do this. Our old Oliver 770 had offset bottom links on the 3 point which looked like the ends of a Pat's. If the offsets were in it was a cat 1, if they were out it was a cat 2. The top link connected to the tractor with a wishbone which had several holes in metal plates so you could move the top link up and down. 4 pins and you could change from a cat 1 to a cat 2, the process took about 2 min.
On a side note I never knew that normal cat 1 and cat 2 hitches didn't come with a Pat's style of catch until I got my John Deere.
   / Any dual Cat1/Cat2 quick attach hitches? #16
Yes I did.
And I looked at the picture.
And I noted your statement that they used to make that product.
Oh, I just LOVE the nitpicking!!! I never said someone USED to make the product, that was another poster (BukitCase).
In fact, LandPride still makes the product in the link in post #8. Unfortunately, it won't work on a 3PH. :stirthepot:
The poor OP asks a simple question, some people try to help out, and it results in an exercise in semantics. :eek:
   / Any dual Cat1/Cat2 quick attach hitches? #17
I thought semantics was navy jargon.
BRuce
   / Any dual Cat1/Cat2 quick attach hitches? #18
   / Any dual Cat1/Cat2 quick attach hitches? #19
Don't most of the cat 1 quick hitches have cat 2 sized hooks and require bushings to fit properly anyway?
   / Any dual Cat1/Cat2 quick attach hitches? #20
Some even have CAT3 hooks.
But the problem is the rigid frame. If the QH is set to CAT 1 width, then that is all it will accept. All implements have to be modified to the CAT 1 standard.
Chain Link Fence (A51573)
Chain Link Fence...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
