Any dual Cat1/Cat2 quick attach hitches?
   / Any dual Cat1/Cat2 quick attach hitches? #11
If you can't find a Priefert, the next closest in function may be Pat's Cat 2 on the tractor and bushings to match on the Cat 1 implement.
Pats Easy Change 3 Point Hitch System
Bruce
   / Any dual Cat1/Cat2 quick attach hitches? #13
   / Any dual Cat1/Cat2 quick attach hitches? #14
I wonder why more tractor companies don't do this. Our old Oliver 770 had offset bottom links on the 3 point which looked like the ends of a Pat's. If the offsets were in it was a cat 1, if they were out it was a cat 2. The top link connected to the tractor with a wishbone which had several holes in metal plates so you could move the top link up and down. 4 pins and you could change from a cat 1 to a cat 2, the process took about 2 min.
On a side note I never knew that normal cat 1 and cat 2 hitches didn't come with a Pat's style of catch until I got my John Deere.
   / Any dual Cat1/Cat2 quick attach hitches? #16
Yes I did.
And I looked at the picture.
And I noted your statement that they used to make that product.
Oh, I just LOVE the nitpicking!!! I never said someone USED to make the product, that was another poster (BukitCase).
In fact, LandPride still makes the product in the link in post #8. Unfortunately, it won't work on a 3PH. :stirthepot:
The poor OP asks a simple question, some people try to help out, and it results in an exercise in semantics. :eek:
   / Any dual Cat1/Cat2 quick attach hitches? #17
I thought semantics was navy jargon.
BRuce
   / Any dual Cat1/Cat2 quick attach hitches? #18
   / Any dual Cat1/Cat2 quick attach hitches? #19
Don't most of the cat 1 quick hitches have cat 2 sized hooks and require bushings to fit properly anyway?
   / Any dual Cat1/Cat2 quick attach hitches? #20
Some even have CAT3 hooks.
But the problem is the rigid frame. If the QH is set to CAT 1 width, then that is all it will accept. All implements have to be modified to the CAT 1 standard.
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
HOMEMADE 4' X 12' SINGLE AXLE TRAILER (A51248)
HOMEMADE 4' X 12'...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
UNUSED CFG MX12RX EXCAVATOR (A51247)
UNUSED CFG MX12RX...
2016 Ford Explorer SUV (A51694)
2016 Ford Explorer...
