2015 Hay Season
   / 2015 Hay Season
Foreman. Backing the bale size down on the monitor does nothing for the density. The density on a rebel is controlled by an arm under the side door. It has a screw knob on it for the adjustment. But I'm sure you know that. The newer 5420 & 5520's run a pressure gauge option for bale density the older ones 5400 & 5410 do not. To my knowledge.
Yeah I adjusted it by the knob but they thought I was over sizing them so I backed down on the size
   / 2015 Hay Season
   / 2015 Hay Season #213
<img src="http://www.tractorbynet.com/forums/files/haying/430799-2015-hay-season-image-jpg"/><img src="http://www.tractorbynet.com/forums/files/haying/430800-2015-hay-season-image-jpg"/><img src="http://www.tractorbynet.com/forums/files/haying/430801-2015-hay-season-image-jpg"/><img src="http://www.tractorbynet.com/forums/files/haying/430802-2015-hay-season-image-jpg"/>
Very peaceful looking setting you have there. Nice tractor too.
   / 2015 Hay Season #214
Must agree with Tom. Very peaceful setting. Nice bailing rig also. Sure doesn't look like you have a problem from the pics.
Any chance you could have a bad batch of belts. Maybe just change belts instead of bailers.
   / 2015 Hay Season
Thanks yeah we are pretty country located. The tractor pulls baler no problem and the ride is nice.
81 bales so far will finish up tomorrow.
Farmer2009 I bale some then work on it at dark and when I get off I put it back together and get after it again.As much as I would like to get a new baler I just don't really won't to spend the money,mine is like new.
   / 2015 Hay Season #216
Maybe the baler doesn't like your "NEW to you" tractor??? Maybe it likes ORANGE better!! There's not much worse than an equipment failure when the hay's ready to bale.
   / 2015 Hay Season
Alright so I finally got pictures what I'm dealing with. The place where grass is in roller is where the bearing went out.
   / 2015 Hay Season #218
That baler should be a long ways from worn out. I have never run a big round baler so i am not the one to answer the questions but somebody should be able to help you. I would start a new thread and see if somebody else picks up on it. Also haytalk.com might be a good thread for you to try. that baler is in too good of shape to not expect to last many more years.
   / 2015 Hay Season
I finished up baled 90 rolls today,had to clean that roller out twice but all else went well.
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
