John Deere 6410 won't move
   / John Deere 6410 won't move
The power quad transmission has it's own oil pump. It supplies pressure for planetary clutch packs and reverse brake. It also lubes the transmission. This relief valve is to protect the pump and is located in the transmission front valve housing. There are also a filter relief valve, and cooler relief valve.
JDparts is down so I could not pull up a drawing.
Does this pump also supply oil to PTO clutch?
   / John Deere 6410 won't move #13
Yes, low system pressure (light ON) from trans pump and PTO will not operate.
At the right rear of the tractor is the PTO valve. It will have test ports marked BRAKE and CLUTCH. System pressure should be 170psi at 1000 engine rpm.
   / John Deere 6410 won't move #14
JDparts is up now. In the drawing Key #30 is the filter relief valve, Key #35 is the lube relief valve, and key #36 is the cooler relief valve.
   / John Deere 6410 won't move #15
So thanks for the info on these relief valves.
There is a procedure for flushing the lube relief valve in Tech manual TM4572. Section 255-10A-55. Page number 990
Looks like this is the next plan for the OP to follow.
Ordered 2 manuals on CD today. Dealer said it could take a week.
   / John Deere 6410 won't move #17
Having just bought a power quad, I am curious what the Reverse Brake is?
   / John Deere 6410 won't move #18
The short answer; Used to reverse power flow thru the transmission by "braking" a gear"
The long answer
There is a ring gear (teeth on ID) that the reverse brake "locks" to the transmission case. There are outer planet gears that mesh to the ring gear and inner planet gears. The inner planet gears mesh with the output shaft. As the planet case rotates the outer planet gears have to turn the opposite direction since they are meshed to the "braked" ring gear. They drive the inner planetary gears, which drive the output shaft in a reverse direction of the input direction.
   / John Deere 6410 won't move #19
Zebrafive, thanks for providing both a short and long answer! I think I just learned something today.
1) Check fluid level
2) Replace trans filter part number AL156625
3) If 1 & 2 do not help it might have the lube relief valve stuck open, or failed trans pump
Got the CDs yesterday. Wish there were pictures on where to hook hose ends.
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
John Deere 6120M (A57148)
John Deere 6120M...
1999 Ford Econoline Van, VIN # 1FTRE14W0XHB81450 (A57453)
1999 Ford...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
