John Deere 6410 won't move
/ John Deere 6410 won't move #1
wiam
Barnet, VT
6500 4WD/ML265 JD 6410
2000 6410 powrquad 24 speed. Round baled with it 2 weeks ago. Everything was fine. Last week I went to use it and it will not move. Low trans pressure ligh and stop light flash when engine is running. PTO does not come on. Test light comes on at solenoids on transmission. 8.5-11 ohms on solenoids. Screw driver sticks to each solenoid when activated. I can hear solenoids moving valves with a stethoscope. Gauge does not move in any gear at test ports on bottom. Remotes will open round baler. 3 point goes up and down. Brakes and steering have pressure. Seems like there is no tranny pressure. I got tractor 2 months ago. I have changed filter by rear axle but not front one yet.
/ John Deere 6410 won't move #2
1) Check fluid level
2) Replace trans filter part number AL156625
3) If 1 & 2 do not help it might have the lube relief valve stuck open, or failed trans pump
There is a procedure for flushing the lube relief valve in Tech manual TM4572. Section 255-10A-55. Page number 990
That would be your choice for manual? How about TM4574? I have the TM 4524 coming today. I am not sure which has best info
/ John Deere 6410 won't move #4
TM4524 is for model 6400 while TM4572 is for model 6410
/ John Deere 6410 won't move #5
TM4572 is operations and tests. It tell how it works and how to test
Tm4574 is repair. It tell how to repair (if you know what needs to be repaired) not how to determine if it needs repair for that TM4572
I would say you need both. If only one TM4572
/ John Deere 6410 won't move #6
Ditto what Zebrafive stated.
New filter did not change anything.
/ John Deere 6410 won't move #8
My next guess is stuck lube relief valve
/ John Deere 6410 won't move #9
"lube relief valve"
What is that? Don't recall hearing a valve called that, and would like to hear more what it is and where it is located in the thick of things. tks
/ John Deere 6410 won't move #10
"lube relief valve"
The power quad transmission has it's own oil pump. It supplies pressure for planetary clutch packs and reverse brake. It also lubes the transmission. This relief valve is to protect the pump and is located in the transmission front valve housing. There are also a filter relief valve, and cooler relief valve.
JDparts is down so I could not pull up a drawing.
Does this pump also supply oil to PTO clutch?
/ John Deere 6410 won't move #13
Yes, low system pressure (light ON) from trans pump and PTO will not operate.
At the right rear of the tractor is the PTO valve. It will have test ports marked BRAKE and CLUTCH. System pressure should be 170psi at 1000 engine rpm.
/ John Deere 6410 won't move #14
JDparts is up now. In the drawing Key #30 is the filter relief valve, Key #35 is the lube relief valve, and key #36 is the cooler relief valve.
/ John Deere 6410 won't move #15
So thanks for the info on these relief valves.
Looks like this is the next plan for the OP to follow.
Ordered 2 manuals on CD today. Dealer said it could take a week.
/ John Deere 6410 won't move #17
Having just bought a power quad, I am curious what the Reverse Brake is?
/ John Deere 6410 won't move #18
The short answer; Used to reverse power flow thru the transmission by "braking" a gear"
The long answer
There is a ring gear (teeth on ID) that the reverse brake "locks" to the transmission case. There are outer planet gears that mesh to the ring gear and inner planet gears. The inner planet gears mesh with the output shaft. As the planet case rotates the outer planet gears have to turn the opposite direction since they are meshed to the "braked" ring gear. They drive the inner planetary gears, which drive the output shaft in a reverse direction of the input direction.
/ John Deere 6410 won't move #19
Zebrafive, thanks for providing both a short and long answer! I think I just learned something today.
Got the CDs yesterday. Wish there were pictures on where to hook hose ends.
2019 PETERBILT 389 TANDEM AXLE SLEEPER (A59905)
2019 PETERBILT 389...
Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
Kivel 48in. Forks...
2017 Ford F-150 Pickup Truck (A59230)
2017 Ford F-150...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
