replacing 5 valve bank with a three valve and a 2 valve bank connected
   / replacing 5 valve bank with a three valve and a 2 valve bank connected
The tag on the end piece where the inlet and outlet are reads model number 40 L0 20, and it is Gresen. I'll try to call Barko tomorrow and see if they know, but like you said, JJ, it might be reliefed that low for safety reasons on that particular application. It's a roof mounted loader, so they might not want too much strain on it. I'm suspicious that the main lift relief has been adjusted up, because nothing stops it.
Just thinking, would there be anything wrong with putting an inline relief valve just before the valve bank, and setting it at 1000. I'm guessing that would make all the valves relieve at 1000. Right, or not?
   / replacing 5 valve bank with a three valve and a 2 valve bank connected #13
Yes, that is correct.
Thanks, JJ. I bet I'll have more questions before I'm done.
JJ, I found a nice, barely used two bank valve on Craigslist for $100, but without float. Would a aftermarket float valve work, and how do they hook into the lines?
   / replacing 5 valve bank with a three valve and a 2 valve bank connected #16
A float valve will have three ports.
20 GPM 1/2" NPT FLOAT VALVE PRINCE SS-2B1D
   / replacing 5 valve bank with a three valve and a 2 valve bank connected #17
Why not get a float kit for the valve you are getting?
   / replacing 5 valve bank with a three valve and a 2 valve bank connected #18
J_J
I never seen a closed center spool valve such as quietrangr requires for his 440C that has float option with 3 ports. Are they available?
   / replacing 5 valve bank with a three valve and a 2 valve bank connected #19
What is contained in a "float kit"? I was thinking a hyd spool valve with float that the spool had different landings machined it spool vs a non float valve.
   / replacing 5 valve bank with a three valve and a 2 valve bank connected #20
A float kit for a spool valve is added on to the bottom of the spool.
If no float valve is attached to the spool, all you have on the bottom of the spool is the centering springs.
http://www.princehyd.com/Portals/0/valves/LvManual.pdf
Go to page 10 as a example of the parts.
Page 14 shows the spool with out float.
SAMSUNG REFRIGERATOR / FREEZER (A54757)
SAMSUNG...
2013 Nissan Rouge SUV (A55758)
2013 Nissan Rouge...
2021 Case 221F Wheel Loader (RIDE AND DRIVE) (LIKE NEW) (A50775)
2021 Case 221F...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
