Brand new XJ2025h and already have a cut hose and hyd leaks?????
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #31
I put on some more ties.
Cheers.
:drink:
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #33
I put on some more ties. Cheers. :drink: <img src="http://www.tractorbynet.com/forums/files/ls-tractor-owning-operating/438227-brand-new-xj2025h-already-have-100_0862-jpg"/> <img src="http://www.tractorbynet.com/forums/files/ls-tractor-owning-operating/438228-brand-new-xj2025h-already-have-100_0863-jpg"/>
You tied it so good I don't see any ties.
well got my new hose today>>> 3" longer and a MUCH nicer and heavier hose...got all re-routed,,,all is well....can you guys post pic of how your 3 hoses are routed under the floor pan ??
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #35
Got my xJ2025h a few weeks ago. Got 9 hours on it so far with no issues except the 3 point sway control adjusters bending when I use the brush hog. Not sure why. I bent them back but now the turnbuckles bind up a little when I try to adjust them. Probably because the threads aren't perfectly straight anymore. Just a flimsy design. But otherwise no issues.
did you check that hose ???????????????????????
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #37
Its dark and a long walk to the barn. Ill look tomorrow.
Any pics of how the 3 hoses are routed under the floorpan
OTE=knightrider955;4221152]Its dark and a long walk to the barn. Ill look tomorrow.[/QUOTE]
well got my new hose and this one is a much nicer heavier hose ....3" longer.....rerouted so I can swivel the handle on the bracket...anyone have a pic of how they are fastened under the floor pan ??
[/QUOTE]
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #40
ok here are pics...just follow the top hose im point to where it wraps under the floor pan...also if you guys don't see an issue pls post pic of how they have the top hose attached to the control box,,,which way its turned....thx
Thanks for the heads up! I'll check ours this afternoon and let you know what I find.
New/Unused 72in Quick Attach Rock Bucket (A51573)
New/Unused 72in...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
WESSEX RMX500 LOT NUMBER 45 (A53084)
WESSEX RMX500 LOT...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
