Brand new XJ2025h and already have a cut hose and hyd leaks?????
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #31
I put on some more ties.
Cheers.
:drink:
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #33
I put on some more ties. Cheers. :drink: <img src="http://www.tractorbynet.com/forums/files/ls-tractor-owning-operating/438227-brand-new-xj2025h-already-have-100_0862-jpg"/> <img src="http://www.tractorbynet.com/forums/files/ls-tractor-owning-operating/438228-brand-new-xj2025h-already-have-100_0863-jpg"/>
You tied it so good I don't see any ties.
well got my new hose today>>> 3" longer and a MUCH nicer and heavier hose...got all re-routed,,,all is well....can you guys post pic of how your 3 hoses are routed under the floor pan ??
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #35
Got my xJ2025h a few weeks ago. Got 9 hours on it so far with no issues except the 3 point sway control adjusters bending when I use the brush hog. Not sure why. I bent them back but now the turnbuckles bind up a little when I try to adjust them. Probably because the threads aren't perfectly straight anymore. Just a flimsy design. But otherwise no issues.
did you check that hose ???????????????????????
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #37
Its dark and a long walk to the barn. Ill look tomorrow.
Any pics of how the 3 hoses are routed under the floorpan
OTE=knightrider955;4221152]Its dark and a long walk to the barn. Ill look tomorrow.[/QUOTE]
well got my new hose and this one is a much nicer heavier hose ....3" longer.....rerouted so I can swivel the handle on the bracket...anyone have a pic of how they are fastened under the floor pan ??
[/QUOTE]
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #40
ok here are pics...just follow the top hose im point to where it wraps under the floor pan...also if you guys don't see an issue pls post pic of how they have the top hose attached to the control box,,,which way its turned....thx
Thanks for the heads up! I'll check ours this afternoon and let you know what I find.
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
Electric Concrete Mixer (A51573)
Electric Concrete...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
2008 UTILITY DRY VAN TRAILER (A52576)
2008 UTILITY DRY...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
LOT NUMBER 250 (A53084)
LOT NUMBER 250...
